Results 1 to 8 of 8
Does brake fluid effect fuel hose?
    Not a cool kid Charlief's Avatar
    Ipswich
    I used some Motion Pro clear pvc fuel line for my brake fluid reservoir line. I've noticed that it seems to be sweating. And the "condensation" is not water. Feels like brake fluid!
    It doesn't seem to be losing any fluid at this time and the brakes are still hard. Is it possible that brake fluid is weeping through the tubing? The tubing be noncompatible with brake fluid?
    I've never seen this before and I'm thinking this hose was wrong to use. Shame because I got a box full of it.
    Me no likey crash
    Derry NH
    Re: Does brake fluid effect fuel hose?
    If you want clear hose, you're going to have to use a silicon hose. Otherwise, you'll need EPDM rubber hose. Pretty much anything else will sweat.
    Ipswich
    But is the sweat just water.... Although it doesn't feel like water or is it brake fluid?
    I just might order some new clear silicon hose just to be safe.
    Me no likey crash
    Lifer eboos's Avatar
    It is permeating brake fluid. Fuel line will not work for very long. There is another type of clear hose that will work, I'll get the info.
    Edit: Here it is - Tygon 2075
    It's likely a mix of brake fluid and moisture. The clear tubing for my MityVac will "sweat" as well as start to appear cloudy if it's been stored for a while. Been using it for many years without issue so, unless it's starting to collapse, I'd say keep on using it.
    Ipswich
    Thanks for the information. I was unaware of the reaction.
    Me no likey crash
    #331 CBR929RE's Avatar
    Bridgewater, MA
    there's no way I'd continue to use that. brakes aren't a place to skimp.
    Ipswich
    Absolutely..... Going to replace asap.
    Me no likey crash
  1. Metric high pressure fuel hose and clamp
    By xxaarraa in forum Bike Maintenance
    Last Post: 07-23-15, 06:46 AM
  2. Replies: 24
    Last Post: 12-12-12, 05:25 PM
  3. brake fluid
    By scubasteveRR in forum Bike Maintenance
    Last Post: 03-08-12, 07:01 AM
  4. question about brakes and brake hose
    By jeffsv in forum Bike Maintenance
    Last Post: 03-19-08, 02:35 PM
  5. brake hose
    By double agent in forum Bike Maintenance
    Last Post: 03-19-07, 06:22 PM
