Results 1 to 8 of 8
brake fluid got on the rotors, now what?
    Member taxonomy's Avatar
    Northampton, MA
    I swapped out my OEM lines for steel and bled the brakes. When doing so I spilled fluid on the rotors.
    I haven't ridden the bike more than a few miles, but it "lacks initial bite!"
    DO I need new pads? How should I clean the rotors?
    Me: "Normal people wouldn't do this."
    Peter: "First you have to operationalize with normal is."
    Gabba Gabba Hey Stiggy's Avatar
    Jan 2009
    Re: brake fluid got on the rotors, now what?
    Try cleaning everything with brake parts cleaner. It may also just burn off with a little use.
    06 RC46
    Funky Buttlover Boston Rexer's Avatar
    Bar Harbor, ME, Southern NH Soon
    Yeah, it should wear off. Use brake cleaner, wipe clean, let dry, then take it for a test ride. At least you didn't spill brake fluid on painted parts! Don't ask me how I know that's a bad thing.
    CLICK HERE FOR MADNESS
    2003 ZRX1200 (Big Green)
    Facebook: toasterdance@hotmail.com
    Northampton, MA
    Thanks guys, off to AutoZone for brake cleaner.
    A
    Jan 2009
    Make sure you don't clean the grease out of the caliper pins!
    06 RC46
    Lifer reiobard's Avatar
    Jul 2005
    Bennington, NH
    Quote Originally Posted by Stiggy View Post
    or better yet, re grease them anyway after cleaning the rotors anyway as general maintenance.
    Lifer Stromper's Avatar
    Eastern Ct
    Brake fluid is water soluble
    Shampoo,rinse,repeat
    Periodically through the season wipe your rotors
    with paper towels and break clean to restore your 1 finger braking
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    If finally you are not satisfied you can remove the pads and using a piece of sandpaper on a flat surface rub them back and forth.
  1. brake fluid
    By scubasteveRR in forum Bike Maintenance
    Last Post: 03-08-12, 07:01 AM
  2. Brake Fluid
    By oVTo in forum Bike Maintenance
    Last Post: 05-26-09, 08:35 AM
  3. Brake fluid etc.
    Last Post: 11-11-05, 02:58 PM
  4. brake fluid
    By double agent in forum Bike Maintenance
    Last Post: 04-23-05, 03:56 PM
  5. brake fluid
    By bemused in forum General Bike Related
    Last Post: 03-14-03, 11:17 AM
