Results 1 to 25 of 38
brake lines??
    I Dance With Will
    Oct 2002
    unknown
    brake lines??
    just wondering if there is any difference between goodrich ss and galfer brake lines. my guess is probably not
    "fuckit!"
    Meriden, Ct
    Re: brake lines??
    They have a completely different brand name.
    I Dance With Will
    Oct 2002
    unknown
    Re: brake lines??
    that's very helpful. thanks
    i mean really?
    "fuckit!"
    Meriden, Ct
    Re: brake lines??
    I was being serious...
    I Dance With Will
    Oct 2002
    unknown
    Re: brake lines??
    ok so you're just saying they are different? i guess material wise it wouldn't matter. i mean they all claim better than stock which is good enough. would the hole diameter be different? i dont know if that matters as well. price are about the same on ebay so i'll just pick whichever.
    "fuckit!"
    Meriden, Ct
    Re: brake lines??
    Take your pick. They are both good products from reputable companies. (ie: pick one, same shit)
    Re: brake lines??
    Like GixerJockey, Goodridge lines have been known to have length issues....a bit too short on certain applications (seriously).
    Also, it's Goodridge........fuckin'-a Kham....they aren't tires are they?
    I Dance With Will
    Oct 2002
    unknown
    Re: brake lines??
    thanks bergs. goodridge... goodshit... sameshit...
    so length maybe a problem? really?
    "fuckit!"
    Nov 2007
    Re: brake lines??
    I have galfers they are nice.
    The only problem is those rifle-droppers don't include any documentation so it's tough at first to figure out orientation.
    i.e.
    what order they go on the banjo
    which end goes at the master and which at the caliper
    which direction the fittings should go from the banjo
    etc.
    You'll have to fudge it for a little while especially since they are pretty stiff and slightly coiled right out of the box.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Re: brake lines??
    On certain new models. If your bike's older than a year I'd say you're safe.
    Lifer Pittenger5's Avatar
    Austin
    Re: brake lines??
    Not in my case.
    Wait wat?
    Zip Tie Alley #505
    I Dance With Will
    Oct 2002
    unknown
    Re: brake lines??
    think i'll go with goodshit.
    do you guys use dot5 or dot4 fluid?
    "fuckit!"
    Re: brake lines??
    you'll be fine with DOT4
    I don't think you can use DOT5 as it reacts with the rubber components of the brake system. I believe DOT5.5 is the alternative....I could be wrong on that so you might want to double check.
    Nov 2007
    Re: brake lines??
    use dot4 motul rbf600
    LRRS/CCS #103
    Meriden, Ct
    Re: brake lines??
    Do NOT use dot5... it is silicone based rather than petroleum. You're break system is not set up for that
    if you want a higher boiling point (you really don't need it, certainly not on the street) then you go with a Dot 5.1. That is a petro based fluid with boiling point characteristics of a dot 5.
    Re: brake lines??
    Quote Originally Posted by ceo012384 View Post
    Meh...not even.
    You'll shit when I tell you what I use in my race bike...
    I Dance With Will
    Oct 2002
    unknown
    Re: brake lines??
    oh crap. thanks. didn't know that. there is a galfer kit that includes dot5. that's all it said but ... oh forget it.
    "fuckit!"
    Meriden, Ct
    Re: brake lines??
    Meh...not even.
    Alright... I'm on the toilet... go for it...
    Posting Freak boloson's Avatar
    Oct 2007
    Re: brake lines??
    dot3, 4, & 5.1 are all ok. DO NOT USE DOT 5.
    oh & spieglers ftw
    Re: brake lines??
    Fast guys don't give away their secrets...
    ...that's why I'm happy to inform you that I use good ole Prestone DOT4 from AutoZone.
    I have yet to see brake fade and appreciate the $$ I'm not spending on the "good stuff".
    I Dance With Will
    Oct 2002
    unknown
    Re: brake lines??
    Quote Originally Posted by boloson View Post
    oh & spieglers ftw
    spieg what? a quick search on ebay didn't come up.
    "fuckit!"
    I Dance With Will
    Oct 2002
    unknown
    Re: brake lines??
    that's the stuff in my zx.
    "fuckit!"
    Nov 2007
    Re: brake lines??
    spiegler
    HEL
    goodridge
    galfer
    etc
    LRRS/CCS #103
    Meriden, Ct
    Re: brake lines??
    Nothing wrong with that... Boiling point is the same either way. That's what the DOT rating is for.
    Nov 2007
    Re: brake lines??
    dry and wet boiling point are both important and are not only dictated by DOT rating
    LRRS/CCS #103
  1. SS brake lines on 95 zx6r
    By nhtodd in forum Bike Maintenance
    Last Post: 01-27-11, 01:33 AM
  2. HEL Brake Lines?
    By Trajiks9 in forum General Bike Related
    Last Post: 04-09-10, 11:21 AM
  3. 01-03 GSX-R SS brake lines
    By Jim in forum For Sale
    Last Post: 09-18-09, 09:20 AM
  4. Braided brake lines..
    By toocrazy2yoo in forum Bike Maintenance
    Last Post: 05-30-09, 03:10 PM
  5. oem brake lines
    By ri-gixxer in forum For Sale
    Last Post: 04-20-09, 04:09 PM
