just wondering if there is any difference between goodrich ss and galfer brake lines. my guess is probably not
"fuckit!"
They have a completely different brand name.
that's very helpful. thanks
i mean really?
"fuckit!"
I was being serious...
ok so you're just saying they are different? i guess material wise it wouldn't matter. i mean they all claim better than stock which is good enough. would the hole diameter be different? i dont know if that matters as well. price are about the same on ebay so i'll just pick whichever.
"fuckit!"
Take your pick. They are both good products from reputable companies. (ie: pick one, same shit)
Like GixerJockey, Goodridge lines have been known to have length issues....a bit too short on certain applications (seriously).
Also, it's Goodridge........fuckin'-a Kham....they aren't tires are they?
I have galfers they are nice.
The only problem is those rifle-droppers don't include any documentation so it's tough at first to figure out orientation.
i.e.
what order they go on the banjo
which end goes at the master and which at the caliper
which direction the fittings should go from the banjo
etc.
You'll have to fudge it for a little while especially since they are pretty stiff and slightly coiled right out of the box.
Zip-Tie Alley Racing
LRRS/CCS #103
think i'll go with goodshit.
do you guys use dot5 or dot4 fluid?
"fuckit!"
you'll be fine with DOT4
I don't think you can use DOT5 as it reacts with the rubber components of the brake system. I believe DOT5.5 is the alternative....I could be wrong on that so you might want to double check.
use dot4 motul rbf600
LRRS/CCS #103
Do NOT use dot5... it is silicone based rather than petroleum. You're break system is not set up for that
if you want a higher boiling point (you really don't need it, certainly not on the street) then you go with a Dot 5.1. That is a petro based fluid with boiling point characteristics of a dot 5.
oh crap. thanks. didn't know that. there is a galfer kit that includes dot5. that's all it said but ... oh forget it.
"fuckit!"
dot3, 4, & 5.1 are all ok. DO NOT USE DOT 5.
oh & spieglers ftw
spiegler
HEL
goodridge
galfer
etc
LRRS/CCS #103
LRRS/CCS #103
