Page 1 of 5 12345 LastLast
Results 1 to 25 of 112
Learned to Fish Tail....
    2WT
    Adams, MA
    Well kinda, got going on wet roads went to shift from first to second and missed the shifter when attempting to shift to second (just a fuggin mistake)
    rear tire started fishtailing from the engine braking, quickly saved it but was kinda fun
    who knows
    Re: Learned to Fish Tail....
    Quote Originally Posted by DuncanMoto View Post
    Everything is fun if you save it.
    and first wipe the poo out of your undies I stopped the hard downshifting in less than ideal conditions after the first time I did that one!
    Saw thread title... knew it was a jc thread.
    Read first post... knew it was a jc post.
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    LRRS 878 Clapped out Gixxah
    PS... you didn't learn how to fishtail, you learned how to make a mistake... luckily the bike recovered for you.
    Nov 2009
    Bristol County
    My first couple times out riding, I learned quickly not to let the clutch out fast. Make that mistake in a turn and it's going to be a wild ride. Bad conditions means easy on the clutch. Especially for people like me who aren't very experienced. I'd also think a bike like yours, aggressive shifting in wet weather in low gears could result in the tire loosing traction even when you do nail the shift...
    nedirtriders.com
    2WT
    Adams, MA
    wait so the jcrawford next to the thread title didn't give it away, you actually had to read it to know
    lol i know it was a mistake This was more a a joke thread about my mistake
    Oh and I kinda feel I recovered it not the bike because I gave the bike the inputs. First thing was pull in the clutch and second was keeping the front wheel straight while letting it even itself out
    Quote Originally Posted by jcrawford View Post
    reply deleted.
    I'm really confused, I would define "fishtailing" as something done under acceleration
    I want my 30 seconds back.
    2WT
    Adams, MA
    I'll give you 10 seconds back, going to be hard to convince me it took 30 seconds to read my first post
    Cabin Fever kb1's Avatar
    Dec 2008
    Down South
    Doesn't that happen to just about anyone that has done some reasonably aggressive riding at the track? I mean going into at least turns 1 and 2 I always have the back end chattering around and I am by no means "fast".
    This.
    *Clever close thread computer code*
    Quote Originally Posted by kb1 View Post
    Only if you downshift way to quickly and let the clutch out too fast.
    Dec 2008
    Down South
    I will add that to the list of things I'm probably doing wrong.
    jcrawford's bike has a factory slipper clutch, so it "shouldnt" chatter when dropped a gear at high RPM's
    Lifer Expat's Avatar
    Mar 2007
    Seriously? Into 2??!!
    Dec 2008
    Down South
    Quote Originally Posted by Expat View Post
    Meant 3, my bad...typing too quickly.
    I try to read the contents people write before I look at the user name... doing it that way helps me avoid being prejudice in my responses.
    Your posts stick out like you wouldn't believe.
    kb1, work on easing out the clutch...
    When I downshift, I usually ease out the clutch as if I'm taking off from a stop in 2nd gear. Doing that would probably solve your rear wheel hop issues.
    Dec 2008
    Down South
    When you downshift, I like to ease out the clutch as if I'm taking off from a stop in 2nd gear.
    I will do that for sure next year, Thanks Pete!
    Dublin, NH
    Isn't a chattering rear tire from a downshift just a sign that the rider didn't rev-match very well? Most rev-matched downshifts I make on my bike in corners seem to come out pretty smooth.
    Granted I don't ride 9/10ths on the track like you guys.
    2023 KTM 890 Adventure R
    To put it very simply, rear wheel hop typicaly occurrs because the rear tire is turning slower than the speed at which the bike is traveling. It grips, slips, grips, slips and the result is chatter or hop.
    Likely causes? Either you didn't "blip" enough, or you didn't ease the clutch out slow enough, or a combination of both.
    Personally, I do a little bit of both but I rely a little more on my clutch slip than my throttle blip (because a strong throttle blip affects my braking precision).
    #331 CBR929RE's Avatar
    Bridgewater, MA
    none of you fuckers can read. he was UPshifting. what I can't figure out is if you completely missed the shifter lever why did you let the clutch out before reaching for the lever again? I can't see how going from first to first would make the bike fishtail except for being hamfisted with the throttle.
  1. Learned something new today!
    Last Post: 07-31-08, 09:13 PM
  2. I learned something
    By wookie in forum General Bike Related
    Last Post: 05-20-08, 01:31 PM
  3. Lessons Learned...
    By bmrider in forum Rides & Events
    Last Post: 07-12-06, 10:58 AM
  4. Lesson learned
    By Jaynnus in forum General Bike Related
    Last Post: 11-18-05, 12:10 PM
