Results 1 to 25 of 27
Where do you buy your chain lube and cleaner?
    Feb 2012
    Quincy
    My research indicates most people recommended kerosene for cleaning. I went by Advance Auto parts today and they got none. Stopped by Walmart and they only have this stuff and no kerosene. Is this kerosene stuff comes in a spray can?
    Where do you buy your chain lube and cleaner?-imag1006-jpg
    So I used wd40 instead. First time cleaning the chain after several thousands miles. Hah the chain turned from Black to silver.
    Try Home Depot.
    May 2011
    Lincoln,RI
    Re: Where do you buy your chain lube and cleaner?
    kerosene is sold at home depot and lowes in big containers, and i use dupont chain saver or dupont all purpose lube.
    Lifer JettaJayGLS's Avatar
    Tahoe City
    I bought kerosene at wal-mart in the camping section...small blue bottle. WD40 works, but isn't the best for o or x-rings, but I've done it too.
    Lancaster
    Wirelessly posted
    Kerosene can be bought at some gas stations or $3-5 a gallon compared to 15-20 at lowes
    Corey
    Feb 2012
    Quincy
    So this kerosene stuff is not in an aerasol can? How do you clean the chain with it then, soak in some kind of cloths? Thanks guys!
    Tahoe City
    Quote Originally Posted by BuXu View Post
    I would remove rear wheel, put about an inch of kerosene in larger tupaware container, put container underneath the swingarm and go section by section dipping it in the kerosene and wiping with a cloth.
    Once done, I would use a spray on lube, ride the bike getting the chain hot, then apply chain wax and let it kinda bake onto the hot chain to minimize spray next time I road.
    Jan 2009
    Middletown, Ct.
    This is insanly to much work. Dip a rag into the kero or use WD-40 in a spray bottle. (Buying a 1 gallon jug of WD-40 and then use a spray bottle to apply it for 1/5th of the cost of the spray cans.) And yes, WD-40 is safe for an O-ring. http://www.advrider.com/forums/showthread.php?t=345397
    For chain wax, I'd been using the dupont teflon that they just stopped making. So I'm no help there as I still have 2 cans left before I need to think about this again. The biggest thing with chains is being dilligent. 500 miles or 1 rain ride, what ever comes first. 23,000 miles, 6 track days out of my first chain on my Triumph.
    Wirelessly posted
    +1 or places that sell home heating fuels
    Junior Member Nny's Avatar
    Aug 2011
    Upstate NY
    +1
    I would also recommend working the chain in a way to remove any debris that a rag can't get to as to reduce any potential binding. You would be surprised at how much crap can get into those little crevices of the chain.
    I know it is a pain but this method is really done once or twice a year in my opinion. Your basic 200-400 mile cleaning is a lot easier.
    May 2012
    Quote Originally Posted by Nny View Post
    I like the Grunge Brush
    who knows
    gallon of kerosene from the gas station... $3.25
    grunge brush... $9.99
    Having a properly cleaned chain... priceless
    Lancaster
    Wirelessly posted
    I buy a gallon of it and have an old wonder bottle that I fill, spray it on the chain, make sure to cover the tire with a towel or something though
    Corey
    soap and water and then the used oil from the oil change.
    buy a spray bottle and fill it with kerosene. use a grunge brush to scrub out any debris, then use shop towels to wipe it all off.
    then motorex Chain Wax to lube
    TWINS! xrocket21's Avatar
    Central Maine
    got my kerosene at the hardware store
    I never clean the chain, just lube it.
    Senior Member SVenpointsixtwo's Avatar
    Jeffersonville, VT
    Quote Originally Posted by drinkingmymilk View Post
    I miss the dupont teflon wax already! I've been using the silicon/teflon stuff as a replacement but it just doesn't stay on like the wax did. Know anywhere to pick up some old stock of the good stuff?
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    May 2011
    Lincoln,RI
    I can't believe they stopped making it! I'll have to run to lowe's or HD and try and buy up a bunch of it. Is the chain saver gone now too?
    Quote Originally Posted by fineout View Post
    I have 2 cans of teflon chain saver you can HAVE. That stuff is terrible. I have never had such a mess. It flung so much, it was dripping off of my oil filter and I thought I had a leak.
    Maxima chain wax or simply WD-40 in a bind from now on for me.
    May 2010
    Somersworth, NH
    ok so we have established that WD-40 is ok for o and x ring chains... is PB Blaster also ok then or is that way more corrosive etc than WD??
    BTW, check Walmart for the Dupont Teflon chain saver. That's where I got mine and less than 3 months ago.
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    An O-ring chain is assembled with grease that has EP (extreme pressure) additives and the o-rings (or Quad rings, X-rings, Z-rings) retain that lubricant. When you use petroleum or mineral based solvents you risk washing out that lubricant and replacing it with the solvent. You can never get that grease back in there, and will severely shorten the life of the chain. The chain lubes you use only coat the external surfaces of the chain, and in doing this it retards corrosion, reduces external roller and sprocket tooth wear and helps keep the chain running smooth and quiet.
    I refer you to Page 4 of this D.I.D. Chains link for more information.
    http://www.didchain.com/chainMaintenance.html
    Posting Freak
    Jan 2003
    Clean the chain with WD40 or CRC Power Lube- get it at Autozone, etc. Honda sells the best chain lube IMHO!
    wow! by that thread, the WD-40 changed o-ring thickness less than PJ-40 chain lube! 1% vs. 4% is negligible...but interesting results.
  1. Best chain lube?
    By Tekime in forum Bike Maintenance
    Last Post: 09-05-18, 09:23 AM
  2. Chain lube
    Last Post: 11-08-08, 12:16 AM
  3. chain lube
    By roso in forum Bike Maintenance
    Last Post: 05-04-06, 05:06 PM
  4. Chain lube
    By NHBusa in forum General Bike Related
    Last Post: 05-19-04, 10:16 AM
    Last Post: 05-28-03, 09:17 PM
