Results 1 to 7 of 7
How much do calipers move?
    Everyone knows that calipers are made to move in relation to the rotor, because a rotor may not be perfectly flat. (obviously, you'd like them to be)
    Anyway, I ask because I did order new caliper bolts (yes, they're pro-bolts) and had to cut them down. I wasn't going to pay $13 each for a titanium bolt and the stainless didn't come in a 25mm, which I need. They came in 20mm and 30mm, go figure.
    After I cut them down, a little is left sticking out the inside of the caliper, in the direction of the rotor. The closest point seems to be the rotor buttons. There Seems to be 3-4mm clearance. Will this be an issue?
    I Dance With Will
    Oct 2002
    unknown
    Re: How much do calipers move?
    couldn't you cut them little more? i would.
    "fuckit!"
    Life is good! gadget's Avatar
    Nov 2008
    Londonderry
    My experience with resizing bolts, is to measure the old bolt with a high tolerance tool (caliper)and cut the new bolt to equal them as perfectly as possible.
    This would include using a fine file to shave .01mm at a time.
    As far as the bolts being to long... did the old bolts do that?
    Brakes are the one thing that I do not take chances with.
    I would rather not go in the first place than to have a possible problem stopping.
    I'm with Kham, I'd file them down a bit more.
    Sam
    Quote Originally Posted by gadget View Post
    I'm pretty low-tech as far as tools go. I cut them down with a Dremel cutting blade.
    Well, I ended up taking about a thread and a half out and now the end of the bolt is flush with the caliper bracket, as it should be and the way the OEM bolts were.
    Thanks for the input. (even Kham )
    Nov 2008
    Londonderry
    glad it worked out...
    btw, a dremel is an awesome tool... far from low-tech
    Sam
    Well, mine's a few years old and purchased at Walmart, so it's on the low end of their scale.
  1. Wanted - Parts & Tools | WTB 06-16 R6 Calipers
    By union in forum Wanted
    Last Post: 03-19-19, 02:17 PM
  2. Just move from NY
    By chickenball z in forum Welcome and Intro
    Last Post: 09-30-07, 09:25 PM
  3. Made the move...
    By senecak19 in forum Pit Area
    Last Post: 06-04-07, 10:39 PM
  4. Move up to JR
    By Kip in forum Pit Area
    Last Post: 08-08-03, 12:59 PM
