Results 1 to 8 of 8
Calling R6S Shift Light Experts
    Member jayth's Avatar
    Aug 2009
    N.H.
    Okay it's a 2007 R6S. I believe I am the #3rd owner fwiw. So here's the scoop, in 2nd gear @ 12000rpm the shift light comes on, and the engine cuts momentarily as if it's on the rev limiter, if I stay on the throttle it will continue to accelerate. As far as I know this only happens in 2nd. 1,3,4 are vetted but getting to 12k in 5th & 6th is not advisable on the street Anyone have specific knowledge with this? My thought is to just shut it off altogether and see what shakes, however I don't want to miss the opportunity to diag an existing condition.
    Re: Calling R6S Shift Light Experts
    ECU flash?
    Aug 2009
    N.H.
    ECU flash?
    Hmmm...Maybe a good old fashioned battery disconnect...
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    you can adjust when the shift light comes on... I can't explain why the bike would cut out though.
    Ecu on the s model I don't think is flashable.
    Aug 2009
    N.H.
    Ugh...
    do you have a Power Commander, Graves ECU, or Bazzaz on there?
    if it's consistently at the same RPM in every gear, it sounds like a possible map issue.
    Aug 2009
    N.H.
    As far as I know it's all stock 'cept for a Yosh' slip on. And it only happens in 2nd @ 12k right when the shift light come on...
  1. Calling Suomy Experts
    By JettaJayGLS in forum General Bike Related
    Last Post: 05-02-16, 02:53 PM
  2. Replies: 5
    Last Post: 04-25-14, 10:43 PM
  3. Replies: 0
    Last Post: 01-09-12, 11:02 AM
  4. tail light out, but brake light works
    By Variablevalve in forum Bike Maintenance
    Last Post: 08-08-09, 09:28 AM
  5. calling all experts on old(er) UJMs!
    By bemused in forum General Bike Related
    Last Post: 07-17-03, 02:36 PM
