Okay it's a 2007 R6S. I believe I am the #3rd owner fwiw. So here's the scoop, in 2nd gear @ 12000rpm the shift light comes on, and the engine cuts momentarily as if it's on the rev limiter, if I stay on the throttle it will continue to accelerate. As far as I know this only happens in 2nd. 1,3,4 are vetted but getting to 12k in 5th & 6th is not advisable on the streetAnyone have specific knowledge with this? My thought is to just shut it off altogether and see what shakes, however I don't want to miss the opportunity to diag an existing condition.
you can adjust when the shift light comes on... I can't explain why the bike would cut out though.
Ecu on the s model I don't think is flashable.
