Results 1 to 25 of 48
I can't get my 'effing drain plug loose...
    Rockin' the West Coast... Femmekat's Avatar
    Jun 2009
    Santa Barbara
    Ok, this is embarrassing, but I'm finally gonna ask for help after my umpteenth unsuccessful try at doing this darn oil change...
    Yet again, lying under the bike this morning on the street, and still can't get the darn drain plug loose. Was cranking on it so hard I almost pulled the bike over on top of me...
    Any male brawn in Bawston wanna flex those muscles? :
    Lifer Pittenger5's Avatar
    Austin
    Wirelessly posted (BlackBerry9530/4.7.0.148 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Muscle? Fuck I'm out
    Zip Tie Alley #505
    Just Registered Doc's Avatar
    Jericho, VT
    Re: I can't get my 'effing drain plug loose...
    Righty tighty, lefty loosey.
    Jun 2009
    Santa Barbara
    Oh! that's what I'm doing wrong.. Sheesh... I am blond, but not that blond.
    Good one
    Wirelessly posted (BlackBerry Curve: BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    Use CEO as a breaker bar
    Jun 2009
    Santa Barbara
    CEO?
    Jericho, VT
    Quote Originally Posted by Femmekat View Post
    Good one
    Kick it.
    Seriously you need a longer wrench to get more torque on it. (breaker bar)
    Jul 2008
    Waitsfield, Vermont
    http://www.craftsman.com/shc/s/p_101...22+flex+handle
    And a set of 6-point, 1/2" drive sockets if you don't have them already (make sure whatever size you need for the drain bolt is included).
    If the breaker bar isn't enough length, get a 4-5' piece of pipe that will fit over the breaker bar. Aluminum lacrosse stick handles will work in a pinch, but might damage the handle in the process.
    Jul 2008
    Marlborough Mass
    Quote Originally Posted by DBKromz View Post
    Rather than trying to brute force it... get out your favorite hammer. Hit the plug from the bottom a few times to help relieve the stress that's built up on it. Yes, I'm dead serious, hit it with a hammer. Then, get your ratchet on it, and play 'impact driver' by hitting the handle with your hand in the direction you want it to turn. You'll get a higher peak impulse of torque on the bolt, and hopefully that combined with the initial hammer session will be enough that it'll loosen up for you.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Are you going in the correct direction. Counter-clockwise. It can be confusing upside down. When you retighten it you could use a new crush washer and a torque wrench.
    Lifer obsolete's Avatar
    Norf Sho
    I got a hammer you can borrow. :-)
    -Alex
    Infected Slyder's Avatar
    Concord, NH
    And after you get the plug lose, don't crank it on there so tight you animal.
    Jun 2009
    Santa Barbara
    Alex, I know you have a hammer and like to use it...
    I will check my useless local hardware store and see if they have a breaker bar. It is doubtful based on past experiences... apparently all you need in Boston are tools for hanging pictures on the wall, so that is what they stock. Got the sockets and a new crush washer...
    Will try using a hammer, and swearing at it profusely...
    Wish I had a torque wrench but those are spendy
    Animal? You know it...lol. :
    Austin
    Bring it to my house ill help ya bang it out
    Zip Tie Alley #505
    Oct 2007
    Peabody Assachusetts
    Are you trying to get it loose with the engine cold? If you take it for a good blast and get the motor hot, that should also help you out!
    Lifer Quigs's Avatar
    Feb 2002
    Quote Originally Posted by brendanp View Post
    If you do this, keep in mind that hot bolts will strip very easily.
    Oct 2007
    Quote Originally Posted by Quigs View Post
    If you are talking about the head of the bolt, that is why she needs to use a 6 point. If you are talking about the threads, I have never heard of this one...
    Heat is always a nice way to get bolts loose.
    Austin
    I need a big strong man to come fix my carbs cause I'm too lazy.
    That ok?
    Zip Tie Alley #505
    Jun 2009
    Santa Barbara
    That ok?
    Lame...
    I had higher expectations Richie....
    Austin
    Thats what she always says.
    Zip Tie Alley #505
    Jun 2009
    Santa Barbara
    That's what she said!
    Jun 2009
    Santa Barbara
    Ok...so a 3 foot metal pipe did the trick... No crush washer in sight... When I put in a new one..which side up? There is a flat side, and a rounded side with an indent along the circumference...
    Jun 2009
    Santa Barbara
    Wham bam thank you ma'am she's done....
    Oh, and Sheppo says split side up on the crush washer
    But... I couldn't replace that because the old one is stuck to the plug.
    Hopefully this will fix the cranky shifting, having to wiggle it into 3rd gear problem I was experiencing on the ride yesterday...
    Jul 2006
    Hollis, NH
    Sheppo says split side up but I couldn't because the old one is stuck to the plug
    hopefully this will fix the cranky having to wiggle it in problem I was experiencing yesterday...
    You go Doug "the old one" Sheppo!
  1. Large piece of metal attached to drain plug - Help me ID
    By Punjistick in forum Bike Maintenance
    Last Post: 08-02-15, 02:03 PM
  2. Stripped oil drain plug of doom. What do I do?
    By mojobreakfast in forum Bike Maintenance
    Last Post: 08-18-12, 03:50 PM
  3. Magnetic Oil Drain Plug
    By Kazinator in forum Bike Maintenance
    Last Post: 09-14-11, 05:36 PM
  4. stripped drain plug
    By Gangsta SV in forum Bike Maintenance
    Last Post: 09-12-05, 02:14 PM
