Results 1 to 10 of 10
carb settings help
    Posting Freak SWEET_Z's Avatar
    Jul 2002
    Smallbany, NY
    carb settings help
    I installed a full hindle exhaust on my bike last week along with a factory config .10 jet kit. I havn't been able to get the carbs set just right. I know I need to sync the carbs but that wont fix these problems right? If anyone has some insight on this it'd be a great help.
    No amount of tinkering with the mixture screws made the cold symptoms go away, only made warm worse or better. I think it may be the floats are set wrong but thats just a guess.
    Symptoms when cold:
    -bike starts up fine with full choke
    -bike used to rev to 2-3.5k while warming and choke engaged. Now It stays below 1.5k with choke engage.
    -If choke is closed before fully warmed (140 degrees) rpms drop below idle or sputters and dies
    Symptoms when warm:
    -rough idle
    -mid range feels strong and smooth
    -high rpms feel good but i don't really have the facilities to test this out on the street. Just the butt dyno.
    THANKS!
    Senior Member Buddhaman's Avatar
    Manchvegas
    Re: carb settings help
    Jetting your bike and not syncing the carbs is a no-no . Now get go get that done and your bike should ride fine and you can have a .
    Jul 2002
    Smallbany, NY
    carb settings help
    So THIS is what I need to do it myself right?
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    carb settings help
    If you really like dealing with toxic mercury, yeah.
    Or, for a much better tool thats more accurate and safer, you could get one of <a href="http://www.carbtune.com">these</a>. I have one on order right now, used one in my buddy's garage, its a GREAT tool, he swears by it even over the expensive digital vacuum guages.
    Cheers,
    Chris
    Jul 2002
    Smallbany, NY
    carb settings help
    I put that stuff on my cheerios!
    Manchvegas
    carb settings help
    Cheers,
    Chris
    Raymond NH
    carb settings help
    Maybe you have a vacuum leak. They are most obvious at idle and less of a problem at larger throttle openings. If you can't get the mixture screws out enough to make the bike idle right, it sure sounds like excess air to me.
    Jul 2002
    Everett, MA
    carb settings help
    Which would be quite quickly revealed when you hook up the vacuum gauges (of whichever variety) and one carb was at drastically lower vacuum, no?
    Cheers,
    Chris
    Jul 2002
    Smallbany, NY
    carb settings help
    Yeh thats a possibility too. It seems to idle ok once warmed though. I think that ussually is a symptom of a lean settings.
    Anyone have a set of vacuum guages and want to make a quick few bucks?
    Raymond NH
    carb settings help
    Cheers,
    Chris
    Not if it's upstream of the sync points
    Edit: scratch that...
  1. suspension settings
    By Rosco61 in forum General Bike Related
    Last Post: 11-30-11, 09:45 PM
  2. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
  3. suspension settings??
    Last Post: 01-17-06, 10:10 PM
  4. suspension settings
    By bara954 in forum Bike Maintenance
    Last Post: 06-06-05, 06:42 PM
