Results 1 to 14 of 14
chain tool recommendations
    san fran
    hey guys,
    just bought a new gear/chain set for my bike and was wondering which chain tool i should get? ive only had experience popping off the retaining clip on dirt bike chains but never the rivet type the street bikes use so im pretty lost as to which tool i should buy. obviously i dont need the "snap-on" of chain tools but i dont like spending money on crap tools either. i figured it would take a shop 3 hours to regear, and put a chain on so i think buying the chain tool and doing it myself would be cheaper.
    Tuono
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: chain tool recommendations
    I bought the one vortex has on their site - seems much beefier than others i've used... been going strong for over a half dozen chains so far.
    san fran
    cool thanks, is there any writeups on how to properly do this? never done it before
    Tuono
    Lake Champlain, VT
    get a tool, post back up. each tool can be slightly different. There's also instructions with the tool IIRC
    san fran
    ahh ok, seems easy enough i just tend to ask lots of questions just for the sake of asking. never know, i always seem to pickup a few tips and tricks doin posts like this. thanks for the info
    Tuono
    Lifer LuvDog's Avatar
    Ashland, MA
    RK Chain Tool.
    It's easy to use and heavy duty. I've had no problem breaking chains and pressing master links with it.
    I've done multiple chains without a problem. I don't even bother dremeling off the mushroom on the links... just press them out.
    2003 ZX7R
    1995 916
    TWINS! xrocket21's Avatar
    Central Maine
    RK Chain Tool.
    You did my chain for my and I think you very much for that, ya did an awesome job, its still going strong!
    Infected Slyder's Avatar
    Concord, NH
    I used the motion pro chain tool, the high end one that does it all, pretty comparable to the RK model I think. It worked slick.
    I went slow with it, I pressed the plate on little at a time and took the tool off and made sure the master link still moved feely...I then did the same when I set the rivet. Go slow and take your time and make sure the master doesn't bind up. If you over do it, well a new master is pretty cheap.
    You probably won't have any problems. I had never done it before so I was nervous but it worked out good
    san fran
    for you guys saying your using the motion pro tool is it this guy?
    Motion Pro - Chain Breaker And Riveting Tool
    Tuono
    Oct 2007
    Peabody Assachusetts
    +1000 to motion pro, you wont have to buy another.
    Concord, NH
    Quote Originally Posted by catch2otwo View Post
    That's the tool I borrowed from my fathers friend.
    Different sized pins and plates, plus as you see on the site replacement parts are readily available.
    definitely worth the price...I noticed most of those chain tools are priced about the same, 80-90 bucks...motion pro lists it as 94 but if you shop around you can get it shipped for that price, probably a little cheaper.
    You could get the RK tool shipped for 90 from motomummy but the RK doesn't look as nice.
    RK Chain Breaker/Rivet Kit :: Chain Tools :: Drivetrain :: MotoMummy Sportbike Accessories
    Nov 2007
    I have an RK chain tool... I haven't used it yet, but from what I can tell compared to some other ones I looked at, it's tits.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    High maintenance priss
    Central MA
    I have the Motion Pro kit (the one Catch linked). Works fine, no complains so far.
    My RK has done numerous chains with only one issue.
    The breaker pin needs to be lubed before the first time you use it or it will shatter.
    Other than that, it's been very reliable so far.
  1. replacement chain/sprocket kit recommendations
    By The Snowman in forum Bike Maintenance
    Last Post: 03-19-08, 12:07 AM
  2. In need of a chain tool
    By nerijusj in forum Bike Maintenance
    Last Post: 08-05-07, 07:07 AM
  3. Chain Tool?
    By Honclfibr in forum Bike Maintenance
    Last Post: 03-10-04, 12:29 PM
