Results 1 to 13 of 13
Clutch cable?
    Lifer reiobard's Avatar
    Jul 2005
    Bennington, NH
    Clutch cable?
    Ok, i have 30,000 miles on my 04 YZF 600 and i noticed that my clutch lever got really slack so i tightened it up about a week ago. I have got roughly 1000 miles since tightening and it seems like it is starting to loosen up again. the adjusters are tight so i know those aren't moving, and on the handle side there is no fraying whatsoever.
    Is it just normal stretching of the cable or is it time to replace the cable? I can't see the clutch end of the cable since it goes inside my sprocket cover so what are the chances that it is fraying down there?
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Clutch cable?
    i'd say time to replace. Cheap insurance
    Clutch cable?
    replace...
    Dec 2003
    Ma
    Clutch cable?
    Check the adjustment nuts where it connects to the motor or replace.
    Clutch cable?
    maybe your clutch needs adjustment
    not familiar with the yzf, all my bike the clutch adjustment is a locknut on the clutch actuater rod (under sprocket cover) , cable adjusters only adjust length of cable that does not have anything to do with adjusting the clutch
    clutch has to be adjusted first before you fiddle with the cable length
    Clutch cable?
    Replace it. Inspect the old one and keep it in your trunk space. That way, if the new one ever snaps, you have a spare to get you home.
    Jul 2005
    Bennington, NH
    Clutch cable?
    Thats what i figured, if i am taking the fairings off and the front sprocket cover off to inspect the other end of the cable, I may just as well replace the damn thing. I don't think i need to adjust the clutch itself, it is not too grabby or slipping at all, it seems to be working fine, just keeps getting slack in the lever which to me says cable stretch.
    Clutch cable?
    Quote Originally Posted by reiobard View Post
    cables don't stretch as much as everybody is leading you to believe,
    more likely your excess cable length is worn clutch plates, replacing cable without adjusting the clutch actuater is assinine
    Clutch cable?
    Anyone ever have a clutch cable snap on you? It starts getting really slack as the strands start to break one by one.
    this process happens alot faster than the wearing out of clutch plates.
    I wouldn't be surprised if it was fraying somewhere inside.
    even if it's not, a new clutch cable is the cheap fix... try that first.
    Clutch cable?
    Yep, Cables turn to taffy, then snap... Have had it happen a few times...
    Clutch cable?
    that happens when you play with the clutch cable instead of adjusting it properly
    Clutch cable?
    no, that happens when a clutch cable begins to chafe on something or inside the housing and begins to break
    Clutch plates don't all of a sudden start wearing out really fast... and if they did, the cable would get MORE taut as it needs to go further to make full contact. His is going slack.
    who does the work on your bike again? the dealer? Phew
    Clutch cable?
    cable begins to chaffe when you ingore your clutch adjustment and fiddle with your cable instead
    no reason a clutch cable shouldn't last 100,000 miles
  1. Wanted - Parts & Tools | 2nd Gen SV650 Clutch Cable
    By Mustang in forum Wanted
    Last Post: 02-02-17, 10:41 PM
  2. WTB clutch cable asap
    By Wishbone in forum Wanted
    Last Post: 04-06-10, 06:52 AM
  3. anyone have a YZF 600R Clutch Cable
    By reiobard in forum General Bike Related
    Last Post: 09-07-07, 12:13 PM
  4. New clutch cable issues
    By neuthunder in forum Bike Maintenance
    Last Post: 07-31-05, 05:27 PM
  5. clutch cable
    Last Post: 07-25-05, 05:50 PM
