Results 1 to 10 of 10
cool little trick
    wus good pimpin Truth's Avatar
    Oct 2007
    sin city,ma
    cool little trick
    ok well i was looking for an easy way to strip paint off the farrings being plastic most paint strippers will eat through them well i found out that dot 3 brake fluid will strip the paint with no harm to the plastic. i read it on another website and decided to try it and to my amazement it worked just thaught id share that
    Southern, NH
    Re: cool little trick
    Damn....that's awesome...thanks
    Old and Slow Sheppo's Avatar
    Westford, Ma
    I would caution about getting the plastics REAL CLEAN after you strip the paint or the new paint will bubble up faster than a herpes sore...
    Posted by Jane in BoxChat
    JACKASS hammadown's Avatar
    Hopkinton, MA
    +1!
    Zip Tie Alley #237
    It is my Understanding That if the Break fluid gets into the material Plastic or metal that it will never be able to hold paint,
    Good luck
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Its caustic and will eat right thru plastic also SO NO>>>>>>Sand it down properly and prep....
    Nothing cuts time when doing Body work Ever....just seems that way untill you paint and the shit doesn't stick ...
    lots of people were Killing Knock off stuff cause of D0t 4.....LOTS
    Meriden, Ct
    "Fish-eye city!!!"
    Waterbury, VT
    As the saying goes - It's called body work, not body fun...
    If you find a paint stripper in a plastic bottle - theres a good chance you can use it on plastic parts (most of the time). Check on a scrap piece if you can before stripping the entire good piece.
    SSearchVT
    Westford, Ma
    Is it a racebike or a street bike?
    Racebike, knock the chipped paint flecks off hit it with some 100 then 150 grit and spray it with Krylon
    Street bike, Spend the time to do proper bodywork. There is no need to sand all the paint off if it is in good shape and paint it according to manufactures specifications.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    It is good for cleaning vinyl like boat covers
    Note if it printed pattern print will be taken off
    Glen Beck is John the Baptist
  1. Trick RD 400.
    By stpierre in forum General Bike Related
    Last Post: 03-18-13, 03:30 PM
  2. trick or treat
    By theothersean in forum Dirty Bastards
    Last Post: 11-01-09, 09:15 PM
