Results 1 to 25 of 25
Crack in Block!!!
    Member masterbomb5000's Avatar
    Oct 2008
    Newton MA
    Crack in Block!!!
    Hey guys just bought myself a 03 cbr 600rr that needs some work for it to get back up to par. was planning to make it a track bike so i had the guy drop it off my house. wasnt surprised but there is a small crack from bottom of block by cover , was wondering if anyone on here knows anyone that is a good welder that can also travel to me. im located in newton MA. worst part about it is this idiot tried to jbweld it and then put this silicone gunk all over it. such a bitch to remove. hoping for good news thanks guys!
    Apr 2006
    Beverly, MA
    Re: Crack in Block!!!
    I don't know about that man. I think it may be time to start scouring EBay for a new motor. I wouldn't trust a welded block...
    Where's the crack?
    Post pics of said Crack...or im on sum
    Old and Slow Sheppo's Avatar
    Westford, Ma
    It is cracked because??? If he left water in it and it froze and cracked get a new motor. I'll bet dollars to donuts it's cracked internally too.
    Posted by Jane in BoxChat
    Dec 2003
    Ma
    JB weld it some more.
    Lancaster, CA
    duct tape
    Lawn Ornament.....
    Oct 2008
    Newton MA
    Where's the crack?
    the crack is right by the cover about 2 inches deep im guessing. will post some pics to get some more feedback. a new motor would cost 500~ so even if thats what it comes down to the bike will be 1600+500=2100 spent, which to me is still quite the a deal.
    Dec 2003
    Ma
    So it has no title huh?
    May 2007
    Southern NH
    ...i think there are folks here who would volunteer to snort it out with a straw...or rolled up 20...
    Muhammad Ali.
    Oct 2008
    Newton MA
    no this thing has a clean title
    pics of it can be found
    http://s111.photobucket.com/albums/n143/masterchen5000/
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    you don't "snort" crack-cocaine
    edit: and oh - if you're willing too buy a new motor, I'd JB weld that one til it dies (not sure fi jay was kidding or not) but JB weld works well on cracked blocks - auto and bike. I'd pull it out and see where the crack goes to make sure the "repair" wasn't in vane.
    Oct 2008
    Newton MA
    yea i guess i will just try to ghetto rig it i mean the crack where the cover seats isnt even all the way through only half cracked as seen in pics. but what else there could be under all that gunk is unknown as of now. will update later with more info.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Pictures suck
    Chip some jb weld out of there
    then brake clean spray
    then jb weld
    then discard that Raoul of San Juan rig
    Glen Beck is John the Baptist
    dave..your valve picture confuses me.
    Freak Posting snowborder's Avatar
    Mt. Wannahuckaloogi
    just a question.... even fixed... Will that ever pass tech inspection? looks like it has the potential to vomit out at any time.
    2001 RC51!!!
    2007 Husky SMR 510 - no longer... blown tranny
    Jun 2005
    no springs... the other cam lobe forces the valve closed.
    Dec 2005
    Near The Dragon
    i presumed you were joking, as per your norm..
    but the desmo valve system uses one lobe to open the valve and another lobe to pull the valve closed and a very light spring usually to hold it to its seat
    Get out while you can
    Find your own path
    Oct 2008
    Newton MA
    Update!:ok so got this bike running after stopping the leak. but it does still have a drop or 2 coming out of the cover which sucks....but im just gonna live with it for now till i get a new motor i guess. but the thing that im confused about is when i drained out all the coolant and put some new honda stuff in and started up the bike for the first time since i bought it last week. runs good. but as the coolant heated up and all the bubbles get pushed out through the cap alot of crap started coming up to the top. very dark mud like oil and i think i even saw some metal shavings for like a sec not 100% on that thou. im guessing there are many things wrong with the motor including a crack in the block. what would your plans be? pics can be found here.
    Sounds like the crack is internal, allowing combustion pressure and oil to push into the cooling system.
    The block cracked because it overheated. That's why you also have a head gasket leak. My guess judging by the paintwork is that it happened during an extended burnout.
    Time for a new motor.
    Aug 2004
    Baltic,CT
    Pull the head and carefully examine the head gasket for a channel from combustion to oil/coolant
    then discard
    Plan would be the 500 dollar tune up... (good used motor) You're wasting your time.
    Senior Member hawk's Avatar
    Sep 2002
    Ma
    Motor is junk.
    Steven
  1. Cam Tower Crack?
    By csmutty in forum Bike Maintenance
    Last Post: 10-14-11, 02:51 PM
