Results 1 to 12 of 12
How much would this 2005 GSXR Anniversary Edition be worth
    Jun 2012
    Westborough
    The bike has around 24k miles. Has been sitting in the garage since early 2010.
    Quick look reveals the following work that may be required:
    Replace both tires.
    Flush the cooling system, and replace the hoses.
    Replace the battery
    Replace all the brake lines. The front brakes don't work at all (Has ~500 miles on the front pads and rotors)
    Last tune-up in 2010 (spark plugs, sync'ing the throttle bodies, etc.).
    The ignition switch is a bit worn. It still works fine, but it feels a bit sloppy. May need to be replaced at some point.
    Chain replaced in '09.
    Anything else I should look for? How much would a bike in its current condition be worth?
    May 2010
    Somersworth, NH
    Re: How much would this 2005 GSXR Anniversary Edition be worth
    ill give you tree fiddy
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    Smell the gas in the tank. It's probably varnished, might gunk up the fuel filter.
    Pics may help.....but 3000 to 4500.....
    $3467.80, goes down by $.14 every day as it ages.
    and if it needs shit.......3K is a good deal I wouldnt jump over 3500-4 for that bike...
    Wirelessly posted
    $500 less than if it wasnt an anniversary bike. That paintjob is puke-worthy.
    04/05 GSX-R 600/750 ?
    $0.00 plus $0.00 shipping and tax rate at 0%
    Littleton, Ma
    well hearing the full story as you have stated i would top out in the 2500-2800 range. Upper part if it is cosmetically in good condition. Bike needs a $1000 worth of work not to mention all the things that may be discovered later after it sat for a year. I wouldn't take the headache unless it was worth it and anything over that would make it a loosing proposition. If you dont mind investing your time i suggest maybe taking some time and knocking a couple of items off the list. This will make a buyer more comfortable. When you have a list like yours everyone will low ball you hard for the current and future "unforseen problems" that they think they will have
    Sep 2007
    Yes, I would walk away. :-)
    Definitely in the 2500-3000 range
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Im betting fork seals and headlight bracket too....
    Jun 2012
    Westborough
    Thanks guys, I ended up not pursuing it, instead would be saving up for a Street Triple R
  1. For Sale - Motorcycles | 2005 Honda Goldwing 30th Anniversary Edition 4675 miles
    By wolfie109 in forum For Sale
    Last Post: 07-31-19, 01:41 PM
  2. For Sale - Motorcycles | 2005 GSX-R 750 20th Anniversary Edition
    By Tekime in forum For Sale
    Last Post: 12-01-17, 03:29 PM
  3. For Sale - Motorcycles | 2013 BMW K1300S Anniversary Edition - Low miles
    By bostongixxer in forum For Sale
    Last Post: 03-07-15, 12:23 PM
  4. 2006 Yamaha R6 Anniversary Edition
    By WinVT in forum For Sale
    Last Post: 08-13-11, 07:03 PM
  5. 2007 Anniversary Edition VFR800
    By scatman in forum For Sale
    Last Post: 07-10-10, 04:24 PM
