Results 1 to 20 of 20
Another decent score
    Goes right along with my Galfer rotors score back in July. (yeah, they're slightly warped, but they don't bother me at all. It just pulses a little.)
    I scored a used Scotts top-mounted steering damper for $100, shipped from a guy on one of the RR forums. It's an older member (from 2005) and they have a trader system on that site, similar to eBay's feedback system, so you can tell if someone has ever f*cked anyone on parts or bike sales.
    The damper has been on a bike that's been sitting for a couple of years, so it'll need to be cleaned up a little and possibly serviced.
    But it comes with everything, damper and mounting bracket. Here's a pic. (pic is missing the bracket that bolts on where the fairing stays and gas tank bolt on, but they're also included.)
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Another decent score
    holy fucking good buy!!!!!!!!!
    Posting Freak
    New Hampshire
    Nice score.
    You know MCwheel does a great job of making bent rotors straight again.
    Just Registered Omahastylin16's Avatar
    Apr 2008
    Scituate, MA
    awesome, buddy of mine has the same one and loooooves it
    "Chatbox...It's like Vegas, for your fingers."
    Originally Posted by CBR_Knight
    in my own thread, let me post this:
    first of all, nothing about sex or play with a female seems interesting or arousing to me....
    "BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    I have one on my RC51 and one on my CBR....
    The MV comes with a piston style Ohlins from the factory (it dosent do shit by the way)
    Quote Originally Posted by Ryno View Post
    More info please..?
    Senior Member nerijusj's Avatar
    Somerville, MA
    To each his own, but I preffer piston style dampers. My Hyperpro RSC saved my ass a bunch of times on track and street Maybe yours is not as good cause that Ohlins comes with the bike from factory instead of "real" aftermarket Ohlins damper I know that's the case for some bikes.
    BTW Chuck, nice score for cheap money! Hopefully it works
    ZX10R
    Ned
    Posting Freak
    New Hampshire
    More info please..?
    www.mcwheel.com
    They do wheels and rotors. I've had a few things done there and always been happy with their work.
    Lifer union's Avatar
    Blackstone, MA
    Ohlins makes two different style piston dampers. They make a standard one and a race one. The standard one that is probably the one that is supplied on factory bikes like the MV. It doesnt have much adjustment at all throughout the range. The race one is a little different. I forget what the difference is. It either had an extra part inside or one less part. Pete could explain it. However the adjustment range is MUCH greater. If you want to compare come on down to the shop some time
    James
    Mar 2004
    Lynn, MA
    Quote Originally Posted by nerijusj View Post
    You are exactly correct. The ones supplied by the manufacturer are not at all the same as the 'aftermarket' Ohlins. The one I have on the bike dosent feel different from full soft to full hard.
    Also, I much prefer the piston style dampers as far as looks go, its just that Ohlins no longer manufactures a mount kit for the RC51. I had no choice but to get the rotary style for that bike.
    Union knows how I feel about that, his RC51 has the piston style, but he had to piece together 2 different kits to get it to work.
    Also my track bike has the Scotts rotary style....it used to be Pete Kates bike, he built it, so it came that way...
    Lifer Pittenger5's Avatar
    Austin
    Zip Tie Alley #505
    get 'em fixed. That's a real problem.
    Umm, OK.
    Problem in what sense? (for the ignorant mechanics, like me)
    Blackstone, MA
    Umm, OK.
    Well since Degsy left you in the dark here...
    What can happen with warped rotors is a few things.
    First they can create hot spots on the rotor. As it rotates where it runs out it can contact the brake pad. This creates friction which creates heat in that part of the rotor while the rest of it is cooling down. This can lead to more warping.
    You will also get unpredictable braking. Depending on how bad the rotor is warped it can push the pistons in the caliper back future then normal. Some of the bad ones Ive seen required two pulls on the brake lever to get some braking response. It can be quite scarey not having the brakes you expect when you looking for them.
    It can also lead to premature pad wear and disc wear.
    James
    I do know this, they feel exactly the same that my stock rotors felt like, except that they seem to grab a little better and the braking is a little smoother than with my stock rotors.
    Blackstone, MA
    Then why ask?
    James
    brap
    Dec 2008
    I got the same one. Sick damper.
    Then why ask?
    Because when someone who really knows bikes like Degsy says that I should have them looked at, I do.
    Does anyone happen to have a stepped link arm for a Scott rotary damper? I received the damper from the member on the other forum and he must have had the other type of fairing stay (there were 2 in '97) which required the flat link arm. Since the damper is probably close to a decade old, he didn't have the stepped link arm. I need to step it upwards, since the tower pin is upwards.
    (otherwise, I have to order one from Scott for $40)
    Here is the issue:
    Forget it. I worked through the issue. I'll take it off and have it serviced in the spring.
    Woo hoo!!
    Now to take the read wheel to Tricky Mike to have the tire patched.
  1. New Helmet Score!
    Last Post: 05-21-08, 02:57 PM
