Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Deglazing rotors...
    Lifer FirstDuc-1098's Avatar
    Central Mass
    Re: Deglazing rotors...
    rotor 'floats' on pins, not attached directly to bike
    Quote Originally Posted by Femmekat View Post
    Cool... How did you like them?
    i've never used them. they came with the wheels i bought.
    Floating type?
    the rotors will wiggle around from the inside. the buttons are those circles that hold the rotor from the center part.
    Quote Originally Posted by jnm988 View Post
    Why do you have to be such a little bitch about it? (Jim, that is)
    Because he knows it makes whiny people like you make stupid comments.
    Go Jim!
    KB KB's Avatar
    Manchester NH
    Put the effing wheels on the bike and let the pads do the de-glazing. Rotors don't glaze, girls faces and brake pads do!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by BLACK SQUIRREL View Post
    Scotch brite Pad Both sides (dry) Give them a good scrub Hit with brake cleaner.
    Not brain surgery as Jim would suggest (for him Maybe it is)
    cause
    Jim Smokes Crack rock
    I've used a scotch brite drill attachment thing on mine. I think it was meant to strip paint off stuff but worked ok on the rotors. I didn't notice any improvement in braking but maybe my pads and rotors weren't glazed.
    edit: nope guess not to strip paint, the one I have is like this but its a drill attachment type http://solutions.3m.com/wps/portal/3...glK6V0H7XKZWbl
    Lauren you can try these. http://solutions.3m.com/wps/portal/3...gl22SKM3MFRFbl
    Oct 2005
    Wrentham MA
    NOTHING stronger than scotch brite pads....
    Don't forget the caliper, if you are going to push them back in (new pads). Don't just push in without removing the grime and buildup on the pistons themselves- the Oring seals that keep the fluid in don't like grime and dirt pushing past them.
    Use a toothbrush and silicon spray, spray and slowly work around the pistons with the toothbrush, spraying to wash away the buildup - obviously you unbolt the caliper to get in there... - nothing stronger such as brake cleaner - the Orings around the pistons don't like that stuff.... when it gets right in there.
    Graham
    Rockin' the West Coast... Femmekat's Avatar
    Jun 2009
    Santa Barbara
    Huh... that looks pretty nifty. Bought an assorted pack of sandpaper after work, and some scotchbrite pads. Just don't tell anyone I will be sanding my rotors on a Friday night... Oh, too late.
    I dunno, you dress too fashionably to be a communist
    LRRS Novice #629
    I ride/drive:
    2000 Yamaha R6
    1996 F-350 4x4 diesel truck
    and anything else with serious hp
  1. 07/08 R1 Rotors
    By chefr1 in forum General Bike Related
    Last Post: 01-20-11, 02:39 PM
  2. EX500 rotors
    By Punjistick in forum Pit Area
    Last Post: 08-23-07, 06:22 PM
  3. WTB F4 Rotors
    Last Post: 02-18-07, 11:05 AM
  4. wave rotors vs standard rotors
    Last Post: 05-26-06, 10:04 PM
  5. Road rotors vs. Race Rotors
    Last Post: 04-29-05, 02:35 PM
