rotor 'floats' on pins, not attached directly to bike
Put the effing wheels on the bike and let the pads do the de-glazing. Rotors don't glaze, girls faces and brake pads do!
I've used a scotch brite drill attachment thing on mine. I think it was meant to strip paint off stuff but worked ok on the rotors. I didn't notice any improvement in braking but maybe my pads and rotors weren't glazed.
edit: nope guess not to strip paint, the one I have is like this but its a drill attachment type http://solutions.3m.com/wps/portal/3...glK6V0H7XKZWbl
Lauren you can try these. http://solutions.3m.com/wps/portal/3...gl22SKM3MFRFbl
LRRS Am #331
NOTHING stronger than scotch brite pads....
Don't forget the caliper, if you are going to push them back in (new pads). Don't just push in without removing the grime and buildup on the pistons themselves- the Oring seals that keep the fluid in don't like grime and dirt pushing past them.
Use a toothbrush and silicon spray, spray and slowly work around the pistons with the toothbrush, spraying to wash away the buildup - obviously you unbolt the caliper to get in there... - nothing stronger such as brake cleaner - the Orings around the pistons don't like that stuff.... when it gets right in there.
Graham
