Results 1 to 25 of 35
stripped fairing bolts
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    How the hell do you get them out? The bolts are on a tail section of an 02 R6 bolted into I believe the sub frame. Need help please.
    Senior Member ku996r's Avatar
    Jul 2006
    shrewsbury, ma
    Re: stripped fairing bolts
    I had something similar happened to my engine mount bolt.
    final solution: weld a correct size hex key and turn it. (thanks dan for this)
    Carlton
    My facebook
    Oct 2002
    Cape Cod
    Quote Originally Posted by ku996r View Post
    final solution: wield a correct size hex key and turn it. (thanks dan for this)
    What do you mean wield?
    Winchester, MA
    Vice grips if you can get them to bite. Otherwise use an ez-out.
    Oct 2002
    Cape Cod
    whats an ez-out?
    come on guys you gotta break it down for me lol
    Winchester, MA
    Craftsman 5 pc. Screw Extractor Set - Includes Screw Extractors No. 1-5 - Model 66202 at Sears.com
    ...Also known as ez-outs. They're reverse threaded so as you drill them into the screw they pull it out.
    However the name is somewhat of a misnomer so try the vice grips first.
    Jul 2006
    shrewsbury, ma
    weld, sorry about the typo.
    be careful using ez-out or any screw extractor, if the bolt is big and requires alot of torque, the ex-out drill bit could snap inside your stripped bolt.
    Carlton
    My facebook
    Oct 2002
    Cape Cod
    Ok im gonna go out there and try and use vice grips and see how that goes....This is such a pain in the ass.
    Winchester, MA
    Very true, and they're hardened which makes them extra fun to remove!
    Lifer reiobard's Avatar
    Jul 2005
    Bennington, NH
    I would just leave the tail on there... F EZ outs...
    Oct 2002
    Cape Cod
    vice grips are too big to fit around the bolt with the little amount of fairing clearence thats provided
    sounds like you'll have to drill a small pilot hole and use the drill extractor to that that bolt out. i broke one on my front sprocket cover this winter. used the EZ Out from sears
    Oct 2002
    Cape Cod
    Quote Originally Posted by reiobard View Post
    I am taking off the tail because I am installing intigrated tail lights/turn signals and need to get to all the wiring. Looks like I might have to bring it too a shop to see if they can take them out for $100
    Winchester, MA
    Can you file a slot into it big enough to use a flathead screwdriver?
    If so, try that and make sure to use the biggest screwdriver you can slot to avoid stripping it again.
    Foxboro, MA
    add this too the tuturial tuesday special
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Winchester, MA
    If at first you don't succeed, here's a few ways to really fuck it up
    Of course my favorite solution to any difficult problem, ala reiobard, is to convince yourself that whatever it is didn't really need doing in the first place
    Oct 2002
    Cape Cod
    I think I am just gonna go to sears and buy a power drill and a screw extractor kit and see how that goes.
    honestly, you'll spend more for the tools than paying the shop to take them out for you. unless you plan on stripping more bolts, i'd ask someone to take the bolt out for you.
    Jul 2006
    shrewsbury, ma
    what size is the bolt? if its not too round off, maybe you can use this
    make sure to use a breaker bar to get extra leverage
    Carlton
    My facebook
    Oct 2002
    Cape Cod
    It would be nice to have a power drill anyways I dont know why I dont have one to begin with.
    Sockets wont work already tried.
    the full extracting kit is like $80, but the EZ Outs are like $2
    Lifer BostonSVkid's Avatar
    Dec 2005
    If you dont have a screw gun you cant call yourself a man.
    2006 Ducati Monster S2R800
    Member flintoid's Avatar
    Apr 2008
    Brighton, MA
    And if you pay someone to do it, you'll just out yourself out of the opportunity to actually pick up tools that you WILL use in the future.
    High maintenance priss
    Central MA
    This kind suck IMO, next to useless for bolts: Craftsman 5 pc. Screw Extractor Set - Includes Screw Extractors No. 1-5 - Model 66202 at Sears.com
    Honclfibr linked this kind, but also implied that they suck...which I'm agreeing with.
    This kind is better: Craftsman 7 pc. Drill-Out/Screw-Out Power Extractors - Model 720SR at Sears.com
    Jul 2005
    Bennington, NH
    2 more pieces, must be better.
    How do you not have a drill????
    The screw extractors don't suck until you break on in the hole...
  1. Stripped threads in oil pan
    By mi1knc0okies in forum Bike Maintenance
    Last Post: 07-28-12, 04:27 PM
  2. TL1000R race fairing & fairing support
    By jeffsv in forum For Sale
    Last Post: 05-07-09, 02:23 PM
  3. fairing bolts + bushings
    By flintoid in forum Bike Maintenance
    Last Post: 07-01-08, 11:37 AM
  4. Stripped bolt or pan?
    By FastJohnny in forum Bike Maintenance
    Last Post: 04-05-07, 03:10 PM
  5. stripped drain plug
    By Gangsta SV in forum Bike Maintenance
    Last Post: 09-12-05, 02:14 PM
