Results 1 to 20 of 20
Educate me...1/4 turn throttle
    still a newbie j4eric's Avatar
    Aug 2009
    Grafton, MA
    A must have?
    Spend your money on something else?
    I'm still learning the track skills and the bike I am looking at buying comes with it......seller is willing to discount 100.00 bucks for the bike without it...
    07 R6 just in case it matters
    08 CBR 1000RR street bike
    99 R6 track bike
    02 F4i sold to a nesr member
    Lancaster
    Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.2; en-us; DROID2 GLOBAL Build/S273) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
    Save the 100 bucks and go with stock, more feel in a stock one
    Corey
    Nov 2008
    Framingham, MA
    Re: Educate me...1/4 turn throttle
    Eric, I suppose Corey is got a good point. I mean the throttle on that 1000rr of yours is very sensitive.
    Nearing the straight away at Jersey I had to twist my wrist real bad...so I got a motion pro kit for the 600rr.
    If you really believe you need the quick action kit, there was is a guy on 600rr.net that sells the HRC quick action tubes for about $45. Otherwise the motion pro kit is a really nice option.
    Regards
    I found a change in how I was gripping the throttle eliminated a LOT of wrist work on the GS (Long throttle action, and you're almost always going right to WOT with a whopping 40hp to 'manage'). Instead of laying your meat hook directly on the throttle like you're preparing to lift a dumbell, come at it from the side, so your arm is aiming in the same direction as the bar itself almost. You'll find the sideways light grip allows you to get a wide range of throttle action with almost no wrist involvement. Hard to describe on a forum, lots of guys can show you in person.
    Aug 2009
    Grafton, MA
    Eddie, it's not for the cbr.....I am looking to get an r6 track bike...but thanks for the input though....still have those brake pads for ya...will get you the model number so you can cross reference.
    99 R6 track bike
    Aug 2009
    Grafton, MA
    Thanks....I believe some already did...it's like holding a screwdriver
    99 R6 track bike
    Nov 2008
    Framingham, MA
    Quote Originally Posted by j4eric View Post
    Nice choice Eric . Can't wait to see it
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Id save the $100
    R6 come with 1/5 or 1/6 turn throttle to begine with, why mod to ¼ turn
    R5 throttle is common mod for ¼turn throttle on other bikes
    The R6 stock throttle is definitely not less than a 1/4 turn. I don't think any stock bikes have true 1/4 turn throw.
    In general, I get BETTER feel with a short throw throttle. I improves my riding because it opens the throttle wider when I crack it open, and as long as you're not spinning, more throttle makes the bike behave better, not to mention it's faster! There is also a big difference in acceleration between WOT at the stops, and 90-95 percent throttle.
    I have never noticed a downside to a short throw throttle on the track. 1/4 turn is actually still a pretty long pull in my world. 1/6 turn is pretty radical. That's about 55 degrees of rotation vs. 90 degrees on a 1/4 turn set up. Most stock bikes are 100 degrees or so in my experience.
    Most bikes are right around 1/4 turn (90*) or MAYBE a hair more from the factory. I personally like a quicker turn throttle on just about any bike and don't see any reason why a rider with any reasonable level of throttle control SHOULDN'T ride a bike with one... but I'm not sure it's worth 100 bucks. That's kinda steep.
    I went with a poor man's quick turn on my SV which consisted of an R6 throttle tube (which has a slightly larger cam than the stock SV) and actually added to the diameter by super glueing a zip tie onto the cam. I haven't measured it accurately but I'm guessing it's right around 70-75 degrees.
    I used an R6 tube on my GS for a bit, loved the action but got bit by the tube not being designed for my throttle housing during a crash. Tube rolled backwards right past the stop. If swapping tubes make sure the stop engages fully in your throttle housing! (SV tubes have a bigger stop on the tube, so SV users should check just to be sure too.)
    Apr 2008
    Boston, MA
    Costs $10 for one with a new grip for Triumphs!
    CBR Airlines Flight 1000 Dragginazz's Avatar
    East of Manch
    Hey Eric! Yeah, like Oreo said, it's easy enough to make the cam bigger yourself! Save the money for something else.
    I just super glued some thin rubber from some rubber tubeing I had laying around to the cam and just trimmed it nice and neat so the cable transitioned easy and that it turned without hanging up. Works very nice!! Throttle turns about 1.5", maybe a tad more or less.
    Good Luck!
    SPEED SAFELY!
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    Can't agree with this enough. I tried the R6 tube on my SV and had it stick open on me. Thankfully, it was a trackday, so I had a little left in reserve to make it through the corner a bit faster once I got it shut, but I know a couple people who weren't so lucky.
    I'm a big fan of a quicker-throw tube for the track, but if you're going that route, I recommend buying one designed for your bike instead of trying to mod one from another machine.
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Newbie BenFer's Avatar
    Pheonix AZ
    I use a motion pro revolver kit. It has 5 different cams and there is no worry about sticking or fitment. Nice piece.
    Hypertarded
    RI / CT border
    tried this out last night, not sure I'm exactly correct with the application, but it seemed to help
    07 R6 comes stock with a 1/6 turn throttle tube. why would you want to get more throw? are you saying the stock one is too short?
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    One way I've heard the proper position described is to hold it like a hammer, not like a dumbbell.
    Quote Originally Posted by Jimmy 2 Shots View Post
    I already said that, but the next post after that seems to claim I was wrong
  1. Replies: 59
    Last Post: 12-24-11, 12:12 PM
  2. NHMS Turn by Turn Journal
    By CEO in forum Pit Area
    Last Post: 08-28-08, 11:54 AM
  3. 1/4 turn throttle.
    By oreo_n2 in forum General Bike Related
    Last Post: 05-23-07, 12:00 PM
