Results 1 to 25 of 41
Failed inspection v. how hard is it to rebuild forks?
    TWINS! xrocket21's Avatar
    Central Maine
    So back in may, I got hassled for the 4th time for my plate location, so I put on a new undertail and mounted the plate correctly.
    Then, of course, it has rained everyday since, so I have been waiting for an inspection.
    Today, the clouds broke, and I went for it.
    during my 30 minute lunch break, I took about 1.5 hours to ride quite a ways to get my bike inspected.
    As expected I got shit about the undertail, but he said that was fine.
    I failed for a leaky fork seal. I have had the bike for 2 years and never noticed it. I looked, and it IS a bit leaky, but I also havent ridden it in a month.
    Do I wipe it off and take it somewhere else?
    How hard is it to replace myself?
    ill be damned if Im gonna pay someone $300 to replace a $10 seal.
    What do I need? Shock oil and a seal kit? are the springs inside gonna take off my head when I take the shock apart?
    Thanks for the help.
    Southern, NH
    Re: Failed inspection v. how hard is it to rebuild forks?
    GMD???
    PM mmracer37
    Central Maine
    GMD???
    I don't know what the means
    Central Maine
    how big of a safety issue is this?
    im really leaning toward wiping off the tiny amount of oil and trying another place
    Apr 2006
    Beverly, MA
    You could have GMD do it if you want it done 100% correctly. Or you could take a whack at it yourself. I've heard seals aren't tough to replace.
    Lifer Pittenger5's Avatar
    Austin
    True, its not like you NEED suspension. People ride rigids all the time.
    Zip Tie Alley #505
    Central Maine
    suprisingly, 1 drop after sitting for a month isnt quite the same as a hole blown out the side of the shock body. There are varying degrees of leaks.
    sounds like you got a leakage problem
    Austin
    True, until a volvo bangs a left in front of you and you have a rigid cause you didnt fix it when you had the chance.
    Zip Tie Alley #505
    Dec 2003
    Ma
    (d) Front Fork Tube Suspension. Inspect and reject if: 1. Front fork suspension has been removed and replace with a solidconnection. 2. There is severe leakage (not slight dampness) of front fork tubeseal
    Wipe it off and go back.
    Before you do, wipe it off. Ride. Check it.
    If it's leaking, replace the seal. If it's not, don't worry about it.
    Central Maine
    I would NOT call it severe leakage... as noted in the pic
    Central Maine
    this is exactly what I was feeling, but I wanted a second opinion
    thanks
    Central Maine
    bike is an 03 rc51 with 25,000 miles
    Dec 2003
    Ma
    That's my point, go back and get your sticker. Also tell us the name of the shop and tech.
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    not to mention no brakes because the oil dripped onto the rotor/pads
    wipe it to get it inspected if you must, but fix it SOON
    Lifer mycirus's Avatar
    Aug 2003
    Whitinsville, MA
    The RC's are wierd about the front fork seals. If you got 25k on em without being serviced its time to get them done anyway. Take it to PK and be done with it. Mine leaked on my RC 2 years ago, Peter fixed it and hasnt been an issue since.
    Bruce
    2007 VFR800 25th Anniversary
    2003 Honda RC51
    Central Maine
    definitely plan on doing both, obviously, even though the left is the only one leaking
    Central Maine
    ehhhhh, I dont think that is necessary, tech seemed like an okay guy
    Yeah, the problem with fork seals is they can go from slight weep to full on gushers in one bump... hence why any sign of a leak results in an inspection failure. If that stuff touches your rotor, you loose any braking you might have had.
    Dec 2003
    Ma
    Sweet as pie I'm sure, even sweeter after you pay him more.
    that guy wheelburns's Avatar
    the mean streets of charlton
    fork seals are not a big deal . . . easy to do with the correct driver.
    just be sure to buy honda oem seals, the after market offerings are garbage.
    if its leaking enough to fail its going to continue to leak.
    and i agree 300 is alot but opening up a fork with no experience is just a dumb idea. a wrong instal and fork oil on your brakes and tire . . . i'm sure you can see where this is going . . . .
    the most important choice in life is if you want to be a tigger or a eeyore
    Raymond NH
    It's easy to replace seals. The factory service manual will spell out the procedure nicely. I highly recommend getting a factory service manual, even if you opt not to work on it yourself. They're cheap enough.
    Central Maine
    I have a digital version, the only tool that is specail i can see is a shock body holder.....
  1. Rebuild forks or buy
    By SRTie4k in forum Bike Maintenance
    Last Post: 08-17-15, 06:56 PM
  2. Failed inspection
    By chicharone in forum General Bike Related
    Last Post: 05-15-06, 10:58 PM
  3. Failed Inspection
    By HBerry in forum General Bike Related
    Last Post: 07-14-05, 05:40 PM
  4. Failed NH state inspection, not surprised. Tire info?
    By Zorlock in forum General Bike Related
    Last Post: 05-05-05, 07:37 PM
