So back in may, I got hassled for the 4th time for my plate location, so I put on a new undertail and mounted the plate correctly.
Then, of course, it has rained everyday since, so I have been waiting for an inspection.
Today, the clouds broke, and I went for it.
during my 30 minute lunch break, I took about 1.5 hours to ride quite a ways to get my bike inspected.
As expected I got shit about the undertail, but he said that was fine.
I failed for a leaky fork seal. I have had the bike for 2 years and never noticed it. I looked, and it IS a bit leaky, but I also havent ridden it in a month.
Do I wipe it off and take it somewhere else?
How hard is it to replace myself?
ill be damned if Im gonna pay someone $300 to replace a $10 seal.
What do I need? Shock oil and a seal kit? are the springs inside gonna take off my head when I take the shock apart?
Thanks for the help.
GMD???
how big of a safety issue is this?
im really leaning toward wiping off the tiny amount of oil and trying another place
You could have GMD do it if you want it done 100% correctly. Or you could take a whack at it yourself. I've heard seals aren't tough to replace.
(d) Front Fork Tube Suspension. Inspect and reject if: 1. Front fork suspension has been removed and replace with a solidconnection. 2. There is severe leakage (not slight dampness) of front fork tubeseal
Wipe it off and go back.
Before you do, wipe it off. Ride. Check it.
If it's leaking, replace the seal. If it's not, don't worry about it.
bike is an 03 rc51 with 25,000 miles
Bruce
2007 VFR800 25th Anniversary
2003 Honda RC51
definitely plan on doing both, obviously, even though the left is the only one leaking
Yeah, the problem with fork seals is they can go from slight weep to full on gushers in one bump... hence why any sign of a leak results in an inspection failure. If that stuff touches your rotor, you loose any braking you might have had.
fork seals are not a big deal . . . easy to do with the correct driver.
just be sure to buy honda oem seals, the after market offerings are garbage.
if its leaking enough to fail its going to continue to leak.
and i agree 300 is alot but opening up a fork with no experience is just a dumb idea. a wrong instal and fork oil on your brakes and tire . . . i'm sure you can see where this is going . . . .
the most important choice in life is if you want to be a tigger or a eeyore
It's easy to replace seals. The factory service manual will spell out the procedure nicely. I highly recommend getting a factory service manual, even if you opt not to work on it yourself. They're cheap enough.
I have a digital version, the only tool that is specail i can see is a shock body holder.....
