Results 1 to 9 of 9
make it Faster.
    Aug 2002
    make it Faster.
    I have a 2001 zx9r and I want more speed, what can I do to make a rocket off the line? Example...I was told to change the front sproket to a 17T...what does it come with stock?
    Blackout Window Tinting
    Chrome Plating
    339-223-0485
    make it Faster.
    If ya want more 'off the line' go up a coupla teeth on your rear sprocket. There's a thread around here with a link to a site explaining any and all gearing questions....
    Senior Member JJ's Avatar
    Aug 2002
    Ashland NH
    make it Faster.
    This should explain it all.....-----> http://www.renthal.com/site/resources/ratios.htm
    That thing got a KAWI in it?????? SWEEEEEET!!!!!!!
    1997 ZX7R LATER JJ
    Pimptastic ftrain's Avatar
    NH
    make it Faster.
    Waz up brotha? I just found this site today. Order a sprocket and maybe a chain online and come to my house. I will throw it on for you. Rear sprocket is best but may require a new chain. Front sprocket is cheapest and does not require a chain.
    Going -1 in the front is about the same as going +3 in the rear. Give me a holla at work if you want me to help you change the sprocket.
    Mike
    ~ FTrain
    Member zx-stewie's Avatar
    Apr 2002
    location location
    make it Faster.
    One of these should do the trick.
    Little more expensive than a sprocket change unfortunately.
    998cc Kit
    Junior Member shaggy's Avatar
    Aug 2003
    MERIDEN,CT
    make it Faster.
    ignition advancer full exhuast system
    Raymond NH
    make it Faster.
    Cheapest way to accelerate harder is to slip the clutch a little more upon taking off...
    If I want to go like hell, I just bring it up to about 3500 to 4000 RPM and slip the clutch until bike catches up with the engine (adding throttle the whole time). Only takes a second or so and if done right the front tire will be skimming the pavement the whole time. Short shift into second at about 9000 to 10,000 RPM and you'lll be right in thg meat of second gear which you can take to the redline without fear of looping, though the front'll come up a bit around 80 MPH.
    What color is your 9R? Mine's the classy candy lime green.
    Aug 2002
    make it Faster.
    Silver and alota chrome.....
    Chrome Plating
    339-223-0485
    Raymond NH
    make it Faster.
    I'd like to see some pictures. Sounds nice.
  1. Replies: 20
    Last Post: 05-17-11, 04:23 PM
  2. One Second Faster?
    By jeffsv in forum Business & Product Reviews
    Last Post: 01-24-08, 11:49 AM
  3. Replies: 7
    Last Post: 02-02-07, 03:35 PM
  4. Faster
    By Awesome in forum General Bike Related
    Last Post: 06-23-05, 12:46 PM
  5. faster dvd
    By double agent in forum General Bike Related
    Last Post: 12-15-04, 10:33 PM
