Results 1 to 13 of 13
I screwed up bigtime
    Bullshit meter pegged scottfromboston's Avatar
    Oct 2009
    Maynard,MA
    I don't often find a new way to F up anymore, but, it happens.
    When I bought the SV in the fall, I did the normal streetbike storage stuff and parked it for the winter. Well, turns out the cooling system was full of straight water. I didn't know this until after I tried to start the bike, when it was making some pretty bad (clanging/banging) noises and dripping water.
    I drained the oil, and, well, it's all water oil mix, as well as additional water.
    Do motorcycles have freeze plugs? How screwed am i here?
    Also, wil a stock Ninja 2005 250 be usable (safe) for my TTD tomorrow? (I'm 170 lb). The FZ1 is apart for fork seals.
    I deserve some ball busting here, but if you guys could wait until after the initial shock has worn off, that would be great.
    ~Scott
    2020 SMC-R
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: I screwed up bigtime
    Sounds like the motor is hurt. It will take a tear down to determine how fooked it is.
    Load the 250 up and have fun.
    Oct 2009
    Maynard,MA
    Looking at SVrider, I'm not the only one to have done this. The freeze plugs blow out and it's no issue. I just hope I didn't do any damage by trying to start it.. Not sure where the banging and clanging came from...
    ~Scott
    2020 SMC-R
    If there are freeze plugs, and they did give way as they should, I'd estimate you wouldn't have a oil/water mix situation.
    Time to tear it down.
    professional lurker burtonboarder23's Avatar
    Nashua, NH
    nothing like leaving scotts for 15 minutes to grab beer and install a printer and coming back to a bucket full of oil and water
    Oct 2009
    Maynard,MA
    The freeze plugs are under the valve covers - water (and sometimes the freeze plugs themselves) travel down into the sump. If the plugs made it down there, it would be the source of my banging/clanging. I guess I'll be two-fiddying it tomorrow, and at a minimum tearing all of the covers off (valve, clutch, generator).
    ~Scott
    2020 SMC-R
    You may have just fucked up the seals in the coolant pump. Hence the milk. As for the banging? Like metal on metal banging, or a a fucked impeller in the waterpump banging?
    Quote Originally Posted by burtonboarder23 View Post
    There goes your shot to join The Samaritans....
    Lifer Danz19899's Avatar
    Grafton, Ma
    if the freeze plugs popped water could have gotten anywhere. hate to say it but if it got into one of the cylinders your probably hydrolocked it and those bad banging noises indicate something expensive broke.
    best bet . . . . find a new motor IMO
    www.bostonmoto.com
    Ride to live, live to ride
    Southington, CT
    Do a compression test....
    Pull the plugs and crank it over... see if there's any noise. If yes... it's deep inside... If not..it's a wristpin/connecting rod issue. If it ONLY clangs when running, it's stuck in your water pump or transmission.
    What do you hear exactly?
    - Sounds like chain on the ground?
    - Sounds like squealing?
    - Sounds like grinding?
    - Sounds like a dime thrown into a fan?
    Dripping water is a good sign... that means the plugs did release.
    The LEAST amount of teardown you have to do is removing the valve covers, water pump and sump pan. So, take the 250.
    Grafton, Ma
    if it was dripping after you cranked it over find where its coming from could have thrown a rod through the block . . . . not kidding seen it happen to a civic
    www.bostonmoto.com
    Grafton, Ma
    the 250 will be fine tho, teach the importance of carrying corner speed
    www.bostonmoto.com
  1. Am I screwed???
    By caloots in forum General Bike Related
    Last Post: 03-26-16, 10:04 AM
  2. im screwed
    By xbubbax in forum General Bike Related
    Last Post: 03-05-08, 04:20 PM
  3. Screwed again...
    By PB in forum Dirty Bastards
    Last Post: 04-11-07, 09:02 AM
  4. Big John Bagged Bigtime
    By Polonius in forum General Bike Related
    Last Post: 06-02-04, 09:24 PM
