Results 1 to 25 of 40
Frame sliders
    Tougher than a lion Sportygurl131's Avatar
    Billerica MA
    Frame sliders
    what brand do you like and y
    Quote Originally Posted by DuncanMoto
    Subaru love is so sweet.
    qoute from a fellow nesrian
    You crazy bitch!!
    2003 sv650s copper!
    Quote Originally Posted by Duffy View Post
    Sportygurl is probably your best bet for meeting and making new friends, she is like the social director or ambassador or something for NESR.
    Lifer Danz19899's Avatar
    Grafton, Ma
    Re: Frame sliders
    i'd gonna do the nesr obligated thing and say woodcraft. Jim lowsided his SV in turn 2 at the Bomo day and it barely scratched the damn thing
    www.bostonmoto.com
    Ride to live, live to ride
    Lifer reiobard's Avatar
    Jul 2005
    Bennington, NH
    Re: Frame sliders
    Woodcraft is very high quality stuff that has been tried and tested. If you don't mind spending some $ for good protection, then that is the way to go!
    Re: Frame sliders
    There are brands besides Woodcraft?
    Posting Freak senecak19's Avatar
    Massachusetts
    Re: Frame sliders
    Woodcraft.... because their functional... and not "fo-sho".
    Member mauro#749's Avatar
    Apr 2010
    ri
    Re: Frame sliders
    I like the woodcraft, save my bike many times
    Re: Frame sliders
    Quote Originally Posted by senecak19 View Post
    They can be (but I also use them because they WORK. I slid my SV in the bowl at NHMS last year and only had a few scratches.)
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.186 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    Woodcraft. $60
    Re: Frame sliders
    Quote Originally Posted by Sportygurl131 View Post
    you have an SV - Motosliders or nothing. They bolt on with one straight bolt through the frame and engine. Nothing beats them. Check out svrider.com while you are at it.
    edit: if you go faired then here is the link for no-cut sliders.
    Re: Frame sliders
    Quote Originally Posted by sveesix View Post
    and if you want to trash your fairings from sliders that fail, go with no-cut.
    i have tested twice and they work perfectly. i have 2 destroyed fairings to prove it
    Wistah
    Re: Frame sliders
    With a naked/half-faired bike like the SV, your options are basically limitless. But I'm somebody that has absolutely zero interest in cutting holes in my stock bodywork, so I've had to look for mfgs that actually do the legwork to engineer proper brackets that allow for good slider location. A lot of brands (like Woodcraft, LSL, Lockhart Philips, Pro-Tek, etc) simply don't do that. So I can only talk about the two brands I've been able to use.
    On my 650R, I went with R&G sliders, and I can tell you for a fact that they work VERY well. The nylon puck did exactly what it was supposed to, and showed only slight signs of wear. But I wanted to keep the look new/clean, so I ordered a new puck and it was extremely easy to replace.
    On my new bike, it was a lot harder to find decent ones that didn't require chopping up the plastic, but Motovation Accessories designed a great kit. Their brackets are a great heavy duty design (enough to make an engineer smile), and the pucks have an amazing feel of quality to them. They also mount to the strongest points of the frame (not the motor), so I can trust they'll do their job if needed.
    Just don't by the cheapo $30-40 special, and in your case something like Woodcraft may be a good option.
    Re: Frame sliders
    Screw no-cuts. In some cases, they CAUSE more damage than they prevent.
    Believe me, having crashed my SV with Woodcraft sliders and only having to replace hard parts that also slid (brake lever, rearset peg, spool slider), I'll never buy another brand.
    All of the parts performed just as they were designed. Only $80 later. Compare that to punctured parts from no-cut sliders, because their brackets bent into parts they shouldn't.
    Don't go for the cosmetic shit. If they require cutting, then do it. Or have someone do it for you. You won't be sorry.
    Wistah
    Re: Frame sliders
    Quote Originally Posted by DBKromz View Post
    Quote Originally Posted by 07BladeRider View Post
    Not all "no-cut" sliders are pieces of shit. The ones with a well designed bracket kit (not some shitty L-bracket job) will hold up better than simple head-bolt mounts. The extra cost for the quality design is well worth it.
    Billerica MA
    Re: Frame sliders
    my bike is going naked... as it is now.. no lower fairing.. ill be doing woodcraft...
    You crazy bitch!!
    2003 sv650s copper!
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    Sporty... Woodcraft or axljak.
    We sell both and I can show you the results of track crashes with them.
    Feb 2008
    Rhody
    Re: Frame sliders
    Sato
    Hyper
    Re: Frame sliders
    The crash:
    The damage (pic is missing the left clip-on, the bar [forgot to mention that above] and brake lever had to be replaced) The result was minimal plastic damage and everything else was easily replaceable parts, as designed:
    Re: Frame sliders
    everyone around here are woodcraft-whores. Motosliders were made for the SV and are tried and tested...they are made to stick out far enough to protect the radiator and the fairings for the specific motorcycle. Check over at SVrider. Many who have used woodcraft sliders on the SV suffer from radiator damage in the smallest of drops. These are why the Motosliders excel - they are made for the SV. Use them or don't use them. After all it is not my bike.
    I am sure that woodcraft would do you fine if you choose that route. Good luck either way.
    Re: Frame sliders
    Ya got me... Woodcraft sucks and I'm a whore.
    Billerica MA
    Re: Frame sliders
    thanks ill look into them as well
    You crazy bitch!!
    2003 sv650s copper!
    Re: Frame sliders
    I like my Motovation frame sliders on the R1. Quality stuff IMO. Or you can opt for some sweet skate board wheel sliders like on the Motard.
    Lifer CMG241's Avatar
    Windham, NH
    Re: Frame sliders
    woodcraft. bike came with Vortex and they were lot longer than Woodcraft which made me think they kept more of the bike off the pavement - wrong. What it did was bend my R6 motor mount when I went "off road" and also strip the threads in the motor. went down bunch o times with WC's and never had a problem. Woodcraft are the only rear sets I would consider also
    Lifer greenmonster's Avatar
    Aug 2003
    Re: Frame sliders
    Looks like I'm SOL. Checked Woodcraft, Vortex, Motivation apps, even checked bike bandit. Nada. That'll teach me not to ride older bikes.
    Oh, I forgot to add, I charge double for Kawasaki's
    "My God, you're gonna have to cool me down, give me an ice block to shove in my pants or something".
    -Barbecue Lou
    Re: Frame sliders
    Quote Originally Posted by greenmonster View Post
    No biggie. I installed Pro-Tec on the 900RR. Annalisa dropped it form a standstill and not one bit of damage to the plastic. Just a little nick out of the slider and the right-side mirror folded in with a little scratch to the outside plastic.
    Re: Frame sliders
    And for the record, I don't like Woodcraft sliders just for the name. I like the solid puck design, which most others don 't offer. More surface means longer slide wear before the puck is useless.
  1. Frame Sliders
    By slaphappytoys in forum General Bike Related
    Last Post: 09-09-11, 06:39 PM
  2. frame sliders
    By frenchy21 in forum Wanted
    Last Post: 07-31-11, 12:12 PM
  3. Anybody need frame sliders?
    By Kitt in forum Pit Area
    Last Post: 05-10-07, 05:52 AM
  4. frame sliders?
    By Adrenalinechic in forum General Bike Related
    Last Post: 02-03-07, 05:02 PM
  5. frame sliders
    By SVRACER01 in forum Pit Area
    Last Post: 06-24-06, 02:15 PM
