Results 1 to 13 of 13
Anyone ever do a frame swap?
    Senior Member btr_ftw's Avatar
    Salem, MA
    Ever since the loss of my bike
    http://www.nestreetriders.com/forum/...er-boston.html
    I've been looking at some dirt cheap bikes that need repair for a winter project.
    Has anyone ever done a frame swap on a bike? How is it?
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Anyone ever do a frame swap?
    Every winter. Gets easier everytime. 1st time was a bitch.
    Dec 2003
    Ma
    Five hours tops.
    Salem, MA
    special out of the ordinary tools needed?
    how about the front forks and the swingarm? any special alignment needed?
    Salem, MA
    every winter?
    what the...
    dare i ask why?
    Dec 2003
    Ma
    Quote Originally Posted by btr_ftw View Post
    I didn't read through the thread you posted. Depends on the bike. F4i needs a tool to take the lock but off the rear frame bolt. You can make one with a cheap socket and a dremmel.
    High maintenance priss
    Central MA
    Yeah, not particularly difficult but will take ya a while first time around. Setup the bike in a place where you know you can leave it for a long while. For the ones I've done, I've left the motor blocked and lift the frame off the motor. Can help to either have a buddy or a engine lift, depending on how tricky it is to lift off.
    Highly recommend getting your hands on a factory service manual. Other than that, if you are good w/ a wrench its not a huge deal.
    Usually only small # (2-4) of specialized nuts depending on the bike. The steering stem requires a adj. pin spanner or toothed socket, and usually the swingarm and maybe a motor mount or two will also require a toothed socket. All of which you can make w/ a dremmel like hessogood said. Here's an example: http://www.komotodraggin.com/engine_hayabusa.htm
    Tag the routing for the wires/cables and label plug pairs. Label the bolt locations. Kinda common sense stuff.
    Plan on doing other maintenance while pulling frame: check plugs, valve clearance, etc... Very easy w/ motor out.
    Jericho, VT
    every winter?
    what the...
    dare i ask why?
    Race bike, Motor swaps. Basically same thing.
    U don't need the Special tool just take the bolt off and slide it out....2-3 hrs for a F4 motor swap
    Salem, MA
    remember im doing more than just a motor swap, considering this is my first time im going to budget in 7 hours lol. going to look at bikes this weekend.
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    took me a couple days to swap everything over to a bare frame. this was on a race bike so no headlights ect.
    Dec 2006
    Manchester
    MAKE SURE YOU MARK WHERE YOU'RE WIRING GOES
    ....... Nazo's Avatar
    Jul 2004
    Its not that bad...marking your wiring is the most important (in my opinion)
    I also had plastic cups marked with the contents, nuts and bolts to specific sections of the bike would have their own cup.
    Once you are actually removing the engine its always easier to have an extra set of hands...you can use a floor jack though like I did.
    ..And be sure you have plenty of beer, you can run out pretty quick if this is your first time.
    Chris
    LRRS Expert #160
  1. swap meets
    By munstarr in forum General Bike Related
    Last Post: 06-17-10, 08:22 AM
  2. my yzf headlight swap
    By dj 96yzf750 in forum General Bike Related
    Last Post: 11-20-09, 06:38 PM
  3. Looking for help with motor swap
    By masterbomb5000 in forum General Bike Related
    Last Post: 06-28-09, 11:33 AM
  4. CCC of VT Gear Swap!
    By out thumped in forum Dirty Bastards
    Last Post: 04-24-09, 03:58 PM
  5. Swap '04 600rr for '05 VTR or '06 F4i?
    By Bonk! in forum General Bike Related
    Last Post: 10-25-07, 10:13 PM
