Page 5 of 5 FirstFirst 12345
Results 101 to 113 of 113
Grom build
  1. #101
    Re: Grom build
    Update: Brembo P32 calipers with Chimera adapter plates.
    With an RCS14 master cylinder, the experts say to use P32 calipers. If you have an RCS15 master cylinder, then P34 calipers.
  2. #102
    Re: Grom build
    rear bracket
  3. #103
    Re: Grom build
    Comparing the stock from caliper with the Brembo
  4. #104
    Re: Grom build
    Front done. because these calipers are generic (OEM for aprillas the ducati's I believe), the front required me to swap the bleeder and banjo locations.
  5. #105
    Re: Grom build
    Comparing the rear caliper with the OEM. This bracket and caliper is easier to install than the front. The previous owner had the brake line installed backwards. So it made a small mess to flip the line before bleeding the brakes.
  6. #106
    Re: Grom build
    Rear caliper done.
  7. #107
    New Haven-ish, CT
    Re: Grom build
    181cc built Grom for sale in Maine
    https://advrider.com/f/threads/2019-...maine.1785049/
    Re: Grom build
    rotors ordered. this should complete the build, i hope.
  9. #109
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Grom build
    Rear caliper done.
    Is your bleeder lower than your banjo here?
    Re: Grom build
    the banjo and bleeder are the same thread pitch. these calipers are universal and swappable. i think i mentioned it in post #104.
    i'll have to check next time i see the bike if i swapped the rear as well as the front.
  11. #111
    Re: Grom build
    Finally got that awful Amazon exhaust replaced. This Japanese brand makes high end parts for small bore bikes. I’ve been looking around for 2 years to score a deal on this exact system. Unfortunately they were only made for the OG models and not the 2nd gen SF. So a little trimming on the frame needs to be done for the pipe to clear. Also a bracket has to be made to reach the can. Will probably have AK Race Fan make a cleaner bracket later on. This exhaust system is the best combo for the specific motor build I have and increases 2-3hp after the aRacer does its auto tune.
  12. #112
    Re: Grom build
  13. #113
    Central Maine
    Re: Grom build
    Well, that looks like its gonna rip! Love the red!
