Page 5 of 5 FirstFirst 12345
Results 101 to 120 of 120
Grom build
  1. #101
    Re: Grom build
    Update: Brembo P32 calipers with Chimera adapter plates.
    With an RCS14 master cylinder, the experts say to use P32 calipers. If you have an RCS15 master cylinder, then P34 calipers.
  2. #102
    Re: Grom build
    rear bracket
  3. #103
    Re: Grom build
    Comparing the stock from caliper with the Brembo
  4. #104
    Re: Grom build
    Front done. because these calipers are generic (OEM for aprillas the ducati's I believe), the front required me to swap the bleeder and banjo locations.
  5. #105
    Re: Grom build
    Comparing the rear caliper with the OEM. This bracket and caliper is easier to install than the front. The previous owner had the brake line installed backwards. So it made a small mess to flip the line before bleeding the brakes.
  6. #106
    Re: Grom build
    Rear caliper done.
  7. #107
    New Haven-ish, CT
    Re: Grom build
    181cc built Grom for sale in Maine
    https://advrider.com/f/threads/2019-...maine.1785049/
    Re: Grom build
    rotors ordered. this should complete the build, i hope.
  9. #109
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Grom build
    Rear caliper done.
    Is your bleeder lower than your banjo here?
    Re: Grom build
    the banjo and bleeder are the same thread pitch. these calipers are universal and swappable. i think i mentioned it in post #104.
    i'll have to check next time i see the bike if i swapped the rear as well as the front.
  11. #111
    Re: Grom build
    Finally got that awful Amazon exhaust replaced. This Japanese brand makes high end parts for small bore bikes. I’ve been looking around for 2 years to score a deal on this exact system. Unfortunately they were only made for the OG models and not the 2nd gen SF. So a little trimming on the frame needs to be done for the pipe to clear. Also a bracket has to be made to reach the can. Will probably have AK Race Fan make a cleaner bracket later on. This exhaust system is the best combo for the specific motor build I have and increases 2-3hp after the aRacer does its auto tune.
  12. #112
    Re: Grom build
  13. #113
    Central Maine
    Re: Grom build
    Well, that looks like its gonna rip! Love the red!
    Re: Grom build
    Marks R7 thread, and James’ threads over the years have inspired me to make one of my own.
    Been track riding since 2009 and racing since 2011. Two years ago, I finally picked up my first pit bike. Unfortunately no one warned me about the obsession over modifying Groms.
    Apologize for using pics from Instagram. It’s all I had in my phone.
    Picked this up and had it delivered via Uship to NJMP on a race weekend
    Fork seals were blown and forks had no oil. So good opportunity to upgrade. Ohlins fork internals installed
    Reached out to the exhaust vendor to get mounting hardware. Bike was using zip ties and wasn’t doing its job.
    The rear tire had a nail in it and was totally worn to the cords. So new tires, installed at NHMS.
    Ditched the airbox and installed something easier to service.
    Upgraded the cam and a flashed ECU. This bumps the rev limiter from 8k to 10k.
    Next was the high flow oil pump, 60% clutch springs, and billet clutch plate. For anyone that knows Honda single cylinder engines, they use an oil spinner to cool everything down and no oil filter. The clutch cover available for these bikes removed the oil spinner (2.5 pounds of rotating mass off the crank) and adds an OEM Honda oil filter.
    The OEM chain spacers are garbage and I wanted spools.
    The bike was used for MiniGP racing so it had -1/+4 gearing. Dropped down a tooth to go +3 and installed a new DID 420 chain. Since I hate clip master links, I safety wired and covered it in silicone.
    Now this is a function mod. Riding in the pits when the ground is wet, my back gets soaked. This $30 piece of plastic from Amazon was well worth it.
    The rear shock was actually a fake replica. The adjuster knobs weren’t actually knobs and just pieces of plastic on the shock. Also had no oil in there. Note the difference in length on the new Ohlins.
    The exhaust can was rattling inside. Got a replacement with new minting hardware.
    Brembo RCS14 master cylinder. Motion Pro Rev3 throttle kit. The new Rev3 has a super short reel.
    Up next is the NEO 181cc 2v motor kit. This is a complete kit with the crank, head, gaskets, cam, and even included the spark plug.
    Piston, crank and internals have been WPC treated. Crank was welded and balanced. Head was ported and polished. Also going with the 5-speed transmission. This motor kit is just as reliable (if not better) than the OEM motor. Horsepower on these kits will triple the horsepower from 8hp to 23-24hp on 93 pump gas.
    Big gotcha is all the other required components. So with the engine build is also:
    - oil cooler
    - bigger fuel injector
    - bigger throttle bodies
    - bigger starter
    - bigger battery
    - oil catch can
    - aRacer ECU and tuning
    - 4th bearing kit to support the crank
    - upgraded chain tensioners
    Because I want to monitor temp, I went with the Koso dash. Totally programmable and had a gear indicator too. Can set your RPM range, red line, and shift light. So it’ll be set properly after a dyno run.
    Finally got my hands back on the NEO181 Grom and installed my finale mods: Galfer wave rotors
  15. #115
    Re: Grom build
    Front before
  16. #116
    Re: Grom build
    Front after:
  17. #117
    Re: Grom build
    Rear before;
  18. #118
    Re: Grom build
    Rear after
  19. #119
    Re: Grom build
    Also this is the first time I’ve been able to ride the bike since the new exhaust. It sounds weird to say but I can notice a big gain in power. This one is definitely pulling much more than the restrictive system I had on there before.
  20. #120
    Central Maine
    Re: Grom build
    Funny you say that. Putting a pipe on the 110 and taking out hte intake screen made a huge difference! Funny how a small hcange on a low HP motor can feel so huge! pops the front tire on the 1-2 shift now! Definitely didn't do that before.
