Results 1 to 13 of 13
GSXR conversion ???'s
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    So someone has offered to trade me a 00' GSXR-600 converted to a 750, has anyone here done the conversion before?
    I just want to make myself familiar w/the swap.
    What is needed to do the conversion properly and parts are different? I assuming the frontend is different between the 600 and 750? What else, ECU?
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: GSXR conversion ???'s
    if it's done, why ask!?!? haha
    ECU, Harness, Motor.
    Forks, Triples, Front brakes
    Full plastic set headlight, tail light, fairing stay
    Swingarm (not sure about rear wheel - think they r both 5.5)
    ... to name a few.
    if it's the same year, probably just the motor and ECU
    Lake Champlain, VT
    They were much more similar in other years - this was kind of "different" than the later suzuki trends, where the 600 & 750 make generation changes ("bi-yearly") at the same time and share 90% of parts (or more - pulled that number from my ass), and the liter bike changes on opposite model years.
    Lake Champlain, VT
    Quote Originally Posted by DBKromz View Post
    fail.
    750 came with chrome option, 600 didn't
    Dec 2008
    Framingham
    Thanks!
    Lake Champlain, VT
    Quote Originally Posted by duganc1717 View Post
    Thanks!
    I wouldn't be opposed to the bike if I were you regardless of how far he took the conversion... I think motor/front end is easy... but if he did body conversion, and didn't source all the required differing mounts, it will never look right.
    Dec 2003
    Lowell
    A 2000 GSXR 600 was the old SRAD body style. That means there is a good chance that the 750 motor is a '99 motor since in 2000 the 750's went to the new gen body style. If he did that then I am pretty sure that the '99 750 motor slips right into the '00 600 frame. If he used an actual '00 750 new gen motor I am unsure of the process involved in getting it properly fitted to a '00 600 old SRAD frame.
    A couple diffs between '96-99 750's and '97-'00 600's
    - In '98 750's went to FI while 600's remained carb'd (This may also mean that he could have possibly fitted the '00 600 with an even older 750, ('96 -'97)motor so as to not have to bring over the FI bits and pieces.)
    - The 750's have a braced swingarm while the 600's don't
    - The 750's have 6 piston front calipers while the 600's have 4.
    - The 750's have upside down front forks while 600's have conventional.
    - The 750's have a 6' rear wheel and come stock with 190 tire, 600's have 5.5 and come stock with 180 tire.
    I would find out more about what he means by 600 to 750 conversion. It could be as simple as him dropping in a '96 750 motor( and various motor related components like the ECU) and calling it a day, or he could have done a real complete overhaul.
    I believe most of this to be pretty accurate, I am by no means an expert but I owned a '98 750 for 5 years and loved every second on it, what a great bike!
    Hope this info was helpful in your decision.
    Lake Champlain, VT
    Quote Originally Posted by ben10281 View Post
    I think the motor mounts (if not the entire frame) are the same (00 750 fits 00 600)
    Also, I am fairly sure the rear is 5.5" on the 750's.
    Dec 2003
    Lowell
    Motor mounts on an '00 750 frame may be the same as '00 600 frame that I am unsure of, but they are definately different frames. The '00 600 frame has a hole in it(on the throttle side) to allow the coolant tube to pass through, hense the little bubble on the fairing where the hose comes through, while the '00 750 (new gen) frame does not.
    Sorry, I should have clarified what bike had a 6" rear wheel. The '96-'99 750 has a 6" rear rim, in '00 they went back to a 5.5" rear rim on the 750. The '00 600 has a 5.5" rear wheel.
    Lake Champlain, VT
    got ya - thank kawasaki for everyone going to the "fatty" wheels in the late 90's... I think they started the trend.
    Dec 2003
    Lowell
    lol, its funny you say that. I knew a couple of kids that used to stuff 200's on their GSXR 6" wheels.
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Is this kids name Anthony? If it is, then its a nice bike. If it isnt, then how the hell would I know about it...Duh.
  1. Sumo Conversion
    By Jewcati in forum General Track Day Talk
    Last Post: 05-08-19, 03:35 PM
  2. Sv 650 520 conversion sprockets
    By ae in forum Wanted
    Last Post: 09-29-11, 11:40 AM
  3. Downshifting after 520 conversion
    By redwinger in forum Bike Maintenance
    Last Post: 07-01-09, 10:05 PM
  4. ANG Conversion?
    By Woodsy in forum General Bike Related
    Last Post: 07-30-08, 10:37 AM
  5. Pit Power? 50 amp conversion
    By nt650hawk in forum Pit Area
    Last Post: 04-16-08, 01:53 PM
