gpr came on my 03 zx6r, dunno why people say they are crap, it works great for me and has been on the bike at least 6 years
i dont have any opinion on the others since no experience with them, however the gpr works great for me
Scotts on my 03 RR...
Works great, but nothing to compare to.
~that which doth not kill me can only make me stronger~
LRRS / CCS - #103
Ohlins linear. Heard good things and it mounts out of the way on my SV.
From brief research, it seems they're easy to rebuild too.
I had 2 choices when replacing the electronic damper on my bike, Hyper Pro or GPR. didn't want a rotary and didn't want a hyper pro because they leak. but you can buy the hyper pro brackets without the damper so that's what I did. then I found a used Ohlins in the right stroke length for my bike. the stock ohlins clamp could't work because laying backwards it would hit the tank and laying forward it would hit the hyper pro bracket. So when I bought the damper I made sure to get one with a clamp that made it stand up. its made by Harris.
Ohlins will also revalve the dampers that come stock on Kawis. they are the same as real Ohlins dampers except the valve has been drilled out to allow for more oil flow thus pretty much negating all its damping affect. it was a legal thing.
GMD ships it back to Ohlins. he sent one out for me.
make sure its not the OEM one or you're still gonna have to have it revalved.
here's mine with just the brackets and no damper
LRRS Am #331
lol ok well i guess that decides it just got an ohlins from an 06 zx10 for 100 shipped. I'll get it and have it revalved and be good to go. Thanks for all the input guys and still by all means keep on chiming in. Pictures of how you have your linear dampers mounted would be sweet two if you don't mind.![]()
I went with the Scotts rotary for the track bike. Less likely to get damaged in a crash.
Have Ohlins linear on street bike.
I think it is clear those are the top 2 choices for many.
holy crap I love this site, hard racing, they have everything. And for realy good prices. Ohlins fork rebound and compression valves for stock forks for 250?! I may actually respring my forks after all.
ehh. They don't have an ohlins mount listed for my year...
Oh the dreams Dave,eh? Id love a set of Ohlins forks and BST carbon wheels. Oh my
Oh dude I was looking thru that website and came a cross the nix30 ohlins forks and brembo mono block calipers and the forged wheels they had... I had to grab a bath towel to mop up all the drool.
Hows the 848 treating you btw? I was seriously considering hocking a kidney for that brutal btw.
ok so damper came in today. the shaft looks in good shape no obvious damage to the outside, but internals are toast. It feels like there is either cavitation in there from too little oil or that there is actually little bits in there that are grunging together at random points thru the stroke. Turning the adjustment knob just about locks it up at full tight and makes it very free at full loose so the damping system seems fine, It just feels like its low on oil and maybe needs a new seal or two. Whatever it is it needs some help. Any one know what ohlins turn around time is? Some people on the 6r forum were recomending kyle racing and said turn around time was like 3-5 days. But then again they were talking about straight up revalve not including service.
Loudog where did you find info on rebuilding them?
*edit* just noticed after playing with it for a bit that there is now some slight oil residue on the shaft. har har har. Any who obviously it needs new seals and fresh oil.
does it feel crunchy? its air in the oil. Ohlins did mine but I forget how long it took and I sent it through GMD.
I've bought stuff from Kyle and they're good people. a revalve will include service since they have to take it apart to revalve it.
LRRS Am #331
Yes, it does feel crunchy it basically feels like my forks did when I serviced them and first started pumping the old oil out of the cartridge. Thats why figured it was cavitation. And thank you for both tips.
