Results 1 to 17 of 17
Got a new headlight for the ATK, what is this little bulb?!?!
    TWINS! xrocket21's Avatar
    Central Maine
    It's a UFO stealth in white
    What is the little dippy light in the headlight housing??
    Seen in the top right of the headlight
    The headlight bulb itself should have high and low beam, so what is this extra light?
    Re: Got a new headlight for the ATK, what is this little bulb?!?!
    Called a "city light". Common in Europe.
    Sweet piece.....back light glow???? Poss
    Central Maine
    just wire it to switched power I guess?
    Im looking forward to the built in blinkers, will look better than the big ugly stalks it currently has
    Yeah. So you can kill the full headlights and just run that little beam in the daytime.
    Central Maine
    The atk has high and low beam options only. Ill probably just tie it in with switched power.
    Meriden, Ct
    Its there to allow fellow motorists to still identify the bike if your headlight should fail.
    And yea, apparently its a European thing. I just changed the headlight bulb in my new Duc and found the same thing. A quick look in the manual cleared things up.
    I thought it was also required in Europe for parking in some areas? My ST3 had a park position on the ignition that would put power to that light and let me pull the key.
    All of the above.
    Senior Member B440's Avatar
    Jul 2012
    Thompson, CT
    I stuck a blue LED in mine.... cause I'm awesome
    Got a new headlight for the ATK, what is this little bulb?!?!-100_2080_zps6c4ffc75-jpgGot a new headlight for the ATK, what is this little bulb?!?!-100_2079_zpsa026242e-jpgGot a new headlight for the ATK, what is this little bulb?!?!-100_2078_zpsa4f7038b-jpg
    City light?
    Central Maine
    Thread update: here it is installed!!!!!!!!!
    Looks pimp.....
    put in a green LED for the times you're parked!!!
    but yes, it's a city light, not required in the USA, and it doesn't hookup to anything so you can wire it any way you like
    Central Maine
    I actually didn't end up hooking it up at all out of laziness. If I had to solder in the harness I would have, but it turned out my old headlight plugged right in, so I didn't mess with it.
    Not sure Im a huge fan of the integrated blinkers, they are white not amber and not super bright. Also, I liked that I could tell when my blinkers were on with the stalk style.
    KB KB's Avatar
    Manchester NH
    That ATK looks well used!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Central Maine
    I have the motocross side panels, I just leave them off as I think it looks better. The bike is actually in great shape! I did have it exhaust deep in mud 2 weeks ago and didn't clean it that well.
    Hopefully meeting user Rambunctious next weekend for a ride!
    edit: a better pic of it
  1. Replies: 2
    Last Post: 10-12-16, 04:08 PM
  2. Headlight incandescent bulb, HID or Halogen bulb
    By zzrrider in forum General Bike Related
    Last Post: 06-23-12, 02:55 PM
  3. H3 silverstar bulb pair (NIB)
    By breakdirt916 in forum For Sale
    Last Post: 06-05-11, 02:24 PM
  4. 23w turn signal bulb
    By tonup in forum Bike Maintenance
    Last Post: 04-11-11, 07:20 PM
  5. Bulb part#?
    By BCT748 in forum Bike Maintenance
    Last Post: 05-24-08, 07:16 PM
