Results 1 to 8 of 8
HID headlight Problem
    Posting Freak
    Oct 2009
    Southern RI
    A few nights ago I rode to walmart in williston and I had a problem with my headlight and I need advice. The low beam bulb on my 08 ZX6 will NOT stay in the socket. I put it in, and rotate it just as i did the high beam (and every other automotive light i've changed) but the problem is, i dont feel the stop. The bulb will keep turning past where it would normally stop. This is the first occurance of this happening with the bulb.
    I can tell by looking at the bulbs base that it's messed up, just because the metal part (that fits into the headlight assembly) isnt sitting straight, it's at an odd angle and i had to straighten it. After getting the bulb in, or so i felt, the bulb fell out of place again today.
    I've called DDM tuning to speak to them and they've asked me to RMA the bulb. But in the mean time i'm wondering, is it possible that whereve the bulb sits in the headlight housing is effed up. (sorry for lack of technical terms) What if the track that the metal goes in is groved or wrecked... Is this even a possibility?
    Does anyone have a spare H9 bulb that is blown preferably i can borrow and attempt to fit and see what's wrong? I'm not going to go on the 300 mile ride home with my low beam bulb not staying secured.
    Lifer rbrais's Avatar
    Brooklyn, CT
    Re: HID headlight Problem
    Does the bulb base get hot? (Dont know much about HID). If it does not get too hot, try gluing it in with silicone. That is temporary and should hold.
    who knows
    just ride with the high beam on? should do the trick.
    Posting Freak
    Oct 2009
    Southern RI
    If i ride with the high beam on i lose the spread and wide angle lighting provided by the low beam. ZX6's has one bulb on for low, and both on for high. I kinda need it.
    Silver Bullet Commuter fjrrider RI's Avatar
    Narragansett, RI
    If you didn't jam the bulb in the base that you say may be cagats then the receptical may still be fine and a new bulb may do it. You can check it with a burned out bulb to see if that will hold. Right-You want all the light you can get. Just heard about another night collision.
    Yamaha lover
    Posting Freak
    Oct 2009
    Southern RI
    Anyone have a burned out H9 bulb?
    KAWASAKI RULES WOOOOO!
    Member noodles44's Avatar
    No Rhoads Island
    If you can't dig one up, Advance probably has H9 bulbs for $6...
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Doesn't sound HID
    some real cheap hids high low is by moving the filimanent in and out
    Just find a good flat wall and just snug the bulbs so it looks low and hich on the wall
    Glen Beck is John the Baptist
  1. Replies: 2
    Last Post: 10-12-16, 04:08 PM
  2. headlight problem on my EX500
    By 2Thumbs Up in forum General Bike Related
    Last Post: 05-20-11, 11:12 AM
  3. Headlight Problem
    By JunoAF in forum Bike Maintenance
    Last Post: 03-27-09, 04:47 PM
  4. 03 R1 headlight
    By chr|s sedition in forum General Bike Related
    Last Post: 06-17-05, 06:07 PM
