Results 26 to 50 of 57
Ice riding
    Re: Ice riding
    Wheels, or tires?
    Sep 2005
    Sutton
    Re: Ice riding
    Wheels. I plan to keep the set I have set up with my studded tires for winter riding in the woods, but would want to get a set of wheels set up for ice.
    Re: Ice riding
    OK If I wanted to get wheels for my KTM 350EXC what would you recommend?
    Snag a set of used wheels, rotors and sprocket off fleabay or a tusk setup from rocky mountain. Dial up frpoffroad.com and order a set of both direction "canadian" screw ice tires. Kiss your discretionary toy fund good bye for a while but be prepared fer sum fun.
    Haverhill, MA
    Re: Ice riding
    No personal experience, yet, but the Tusk Impact wheel set from Rocky Mountain ATV is inexpensive comparatively and from what the people I know that have them have said, as well as the reviews of them online, they are a decent purchase. I will likely buy a set for my YZ at some point in the relatively near future.
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Re: Ice riding
    I think i have tusk wheels for the second set on my KTM.
    Lets just say I wanted to ride ice this year.... would I be better served getting the icey setup for a crf450r supermoto or my woodsey ktm300?
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: Ice riding
    Your 300 will likely start better on cold days unless you has a button. If you have two wheel sets for the Kaboom I would go that way
    Hiram, ME
    Re: Ice riding
    Good point. Dirt bikes are fickle with cold. Make sure anything you plan to ride on ice will start well in below freezing temps. Spending an hour kicking isn't fun. I know.
    Hiram, ME
    Re: Ice riding
    Thanks Kurtz I was hoping you would weigh in. I guess just ice would be where I would start out. Just got a pm about wheels on ADVrider at a good price.
    Yeah if you can find cheap wheels and swing a set of ice tires, do it. Used ice tires pop up from time to time too, as fast guys upgrade.
    But seriously, if you don't have a setup in time, come try it. I'm hoping to get out more than twice this year.
    Sep 2010
    Granville, NY
    Re: Ice riding
    By all means show up some weekend when we are riding and introduce yourself. Most guys are pretty good about letting you go for a rip. It's like heroin though. Be prepared. Lol
    As Paul said, you can have a fricking ball on a 150f. Hell. I've had a ball on a CRF80.
    Ice riding-cr2-jpg
    My daughter out on the CR having fun getting used to it.
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Re: Ice riding
    This will be my first season ever on "real" ice tires, first time even riding on them! I have them mounted on a spare rim set for the KTM 250xc so I'm looking forward to it.
    Re: Ice riding
    Holy foook, you are in for a treat!
    Re: Ice riding
    Rejet and the machine will probably start easier. Mine usually starts and runs well jetted to the KTM book. I run the same pilot year round but the main and needle both get swapped.
    Paul, he said XC, not XC-F.
    Hiram, ME
    Re: Ice riding
    I added a snowmobile type fuel primer, per Mr. Butler's suggestion. CR250 starts like a champ now.
    KTM never needed it. Magic button always did the trick.
    Re: Ice riding
    I know what he said
    Lifer 01xj's Avatar
    CT
    Re: Ice riding
    Found a set of wheels at a good price. By the time it's cold enough to ride I'll likely have the whole set up. I'll probably need some assistance mounting the wheels and tires since I've never done that before.
    Re: Ice riding
    Yes, you will. Guidance from the master-
    The playlist there has a LOT of good info. Much like getting laid, getting them hot, lots of lube, a couple drinks, and experience make it all go easier. Much like porn however, that vid makes it look far easier than it is. Also make triple sure your tires are on forwards. I screwed up my first try, and the handling is awful. My first season I had three flats on one bike (all rear). After following that vid, three bikes with NO flats. That double tube seems to be the trick. The ultra heavy tubes are awful to buy, install, and ride due to the weight. Note that no bead locks are used, running 15-20 PSI keeps the tire in place. Maybe your DR doesn't have them anyway.
    New Haven-ish, CT
    Re: Ice riding
    I can't believe that 1) you're going to try to ride that beast on ice, and 2) that no one else in this thread has said you're nuts for considering it.
    Hiram, ME
    Re: Ice riding
    FUCK. THAT.
    I've paid to have all my ice tires mounted. Blood and time are worth it. Manchester Honda/KTM did my brand new KTM wheels and Fourniers, and Libby's replace a tube for my CR250.
    Re: Ice riding
    Make sure in advance the shop knows how to do them. I've heard of a couple broken beads due to brutality, ruining an otherwise perfect and fucking expensive tire. I haven't bled yet, but there was a lot of profanity until I learned some technique and accepted that it takes a while.
    Sep 2012
    Southwick,MA
    Re: Ice riding
    FUCK. THAT.
    Haha last time I changed ice tires...this was taking em OFF (so the easier part) last season after not getting a chance to use them at all the whole season because of weather, I ended up bleeding and it left marks that look like I tried slitting my wrists! This was trying to be careful, with the canvas wraps in place. Those screws are sharp as hell, and everywhere. Fuck that. When I found a set of wheels, I was able to convince the dudes at the Dunlop track day at southwick mx to mount them and was so happy when they agreed for something like $15 a wheel. Never again!
    Re: Ice riding
    I got my tires in the middle of winter. Couldn't lay 'em out in the sun to warm up or anything. I set them up in front of the wood stove and let them soak for a while. Barely helped. I wound up mounting them on the floor of the living room on a scrap of old carpet. It was too cold in the basement. Took me hours of swearing. I never, ever, ever want to unmount or remount those tires. Ever.
    I have a heat gun now and would probably point that at everything were I to have to try again. The rear is insanely thick and heavy. The rubber seems extra hard. Bead had zero give and was a nightmare to keep in the dish.
    Re: Ice riding
    Watched my buddy move bikes around with one of these the other day, worked a lot better than I expected. Does that work?
    Attachment 45880
    Not really, its 1/4 mile to the first pond, 1/2 mile to the second pond...all trail. Unfortunately I think the second pond will make a better ice track.
    downhill all the way ? you could ice up a trail that would double as a bobsled run
    Both up and down, but as mentioned above, its a bit far
    Re: Ice riding
    Build a timberframe barn at said pond with a wood stove. Easy peasy.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Re: Ice riding
    don't be like me kids... on the other hand... It builds character. And after a while... a mighty kick.
  25. #50
    Haverhill, MA
    Re: Ice riding
    This could double as a warming hut!
  1. Riding
    By 06gixgirl in forum Rides & Events
    Last Post: 08-23-11, 11:56 AM
  2. Riding Courses - Group Riding etc. Gauging Interest
    By csmutty in forum General Bike Related
    Last Post: 02-08-11, 09:23 PM
  3. anyone riding out there?
    By xbubbax in forum General Bike Related
    Last Post: 02-22-08, 01:12 PM
  4. Riding the way they should
    By Rice-rocket1 in forum General Bike Related
    Last Post: 09-06-05, 02:07 PM
  5. Riding
    By GMAN226 in forum General Bike Related
    Last Post: 02-24-03, 10:44 PM
