Results 1 to 3 of 3
Installed Stainless Steel Lines couple ?'s
    Hood Rich Lucky13's Avatar
    Aug 2004
    South Shore
    I installed front SS lines on my sv yesterday and have a couple of questions/comments on the bleeding.
    1) Speed Bleeders are great! 2) The caliper nuts Galfter sent me did not fit, so I used the original bolt. Seemed to work fine, but will I be okay? 3) I kept pumping and pumping and I could never seem to get all the bubbles out. There always seemed to a few microscopic bubbles here and there. Is this normal?
    Clyde
    03 sv650s
    Member WOTEugene's Avatar
    Jul 2004
    Allston, MA
    Did you get a bleeder valve for your master cylinder banjo bolt? There's probably air in there at the top of the lines where they connect to the master cyl. In case you don't have a bleeder on there, you can still bleed it the ghetto way - put a lot of paper towels and shit around it, pump up the pressure in the brake system and while applying pressure on the brake, uncsrew the banjo fitting at the master cylinder till you hear air escaping & see brake fluid squirting out. Then quickly tighten the fitting back before you release the brake lever... repeat.
    I had to go through all this when replacing the MC, calipers, & lines on my Z... it's a pain in the ass and gets messy, but, ya gotta do what ya gotta do
    Just Registered 13's Avatar
    Dec 2003
    Auburn, NH
    If you've got all except the microscopic air out you should be fine! Now it's time to go out and hammer on that thing!
    One of the former LRRS #13's
    http://www.facebook.com/ChrisWatt762
    JT42
  1. 32 qt stainless steel brew pot
    By burtonboarder23 in forum Wanted
    Last Post: 10-04-11, 03:36 PM
  2. Stainless steel should not pit, right?
    By AimlessMoto in forum General Bike Related
    Last Post: 05-11-11, 02:11 PM
  3. stainless steel mini fridge
    By Kitt in forum For Sale
    Last Post: 04-22-09, 03:03 PM
  4. Where to buy Stainless Brake Lines?
    By smoothwaterman in forum Bike Maintenance
    Last Post: 07-06-05, 05:55 PM
  5. Stainless Steel Brake Line
    By craig in forum Bike Maintenance
    Last Post: 08-28-04, 12:01 PM
