Results 1 to 10 of 10
Installing Clip-ons
    Installing Clip-ons
    didn't get many replies in Maint. so here goes again...
    You'd THINK it wouldn't be a project. and i guess it wouldn't be if they fit w/o any issues.
    But unfortunately the Woodcrafts i got from GMD Computrack are too low I'm gonna have to either find a set that are slightly raised or ride w/o the ram air tube covers (they interfere w/ lock-to-lock steering, as does the headlight assembly) and either get a longer tube for the brake fluid resevoir, or mount the resevoir lower so it reaches the brake lever. I'd also have to re-route my throttle cables & re-lube em so they're not so friggin slow.... the lowered bars make the cables do a tighter bend then they would otherwise preferr.... what a bummer.
    any suggestions?
    (i can't mount em above the tripple clamp, since the stockers mount below & there's only about 8mm of shock above the tripples. so they're mounted as high on the shocks as they can get.)
    Winchester, MA
    Re: Installing Clip-ons
    Originally posted by OreoGaborio
    any suggestions?
    (Or get G forks)
    Installing Clip-ons
    Well folks, it seems to me that someone doesn't want to see his front stand evvverrrr agaaaiiiin
    (wtf are G forks? the ones you have so i can mount em on top of the tripples? pfft, what a shitty downgrade )
    Winchester, MA
    Installing Clip-ons
    Yeah, forks from a ZX6RG1 or G2. I didn't say it was an upgrade, I said it would work
    You already know all the possible solutions. Get a stock set of J1 bars with the 1/2 rise (or a set of helibars, but they're 189 and also a "downgrade" for the track) or do a bit of bending/fabbing to run with the woodcrafts. You have learned all there is to learn, grasshopper. Go forth and wreak damage to your bike.
    And you better be nice to my triple stand or I'll in the gloves you left in my truck
    Installing Clip-ons
    you & your boyfriend better be pretty small in order for you to suck his dick while you're in my ski gloves
    Installing Clip-ons
    You sure you got the right parts? You can rotate 'em when ya mount 'em. Maybe if you rotate 'em forward it'll give you the clearance you need, Clarence...
    They're made to help you get under your windscreen. Perhaps you're trying to set 'em up more for comfort rather than for their intended purpose (lower & further reach than stock)...
    Installing Clip-ons
    nah, they're about 2 inches lower than stock, even though they're mounted in the same location... it's cuz the stockers are rasied up...
    if i swivel em forward then they hit the headlight assembly when i turn the other way... push em lower on the forks & they hit even more
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    Installing Clip-ons
    Installing Clip Ons on Street Faired Bike == Sawzall + Dremel + Wires + New Brake Lines + Sweat + Tears + 1 Carefully Removed Finger == Success
    May 2003
    Lakes Region, NH
    any suggestions?
    ummm yeah - don't crash your bike asshole
    Bras cause cancer.
    Installing Clip-ons
    Guess i gotta return the woodcrafts & hittin up Ronayers.com... 60 bucks & another week later maybe i'll get to ride
    (but hey... at least the handlebar perch is only 60 bucks shipped)
  1. I need help with installing...
    By dipthat in forum General Bike Related
    Last Post: 06-03-10, 12:25 PM
  2. Help installing R6 exhaust
    By Kitt in forum Pit Area
    Last Post: 05-25-10, 12:34 PM
  3. Installing Lights on a CRF
    By lrrs428 in forum Pit Area
    Last Post: 03-17-10, 02:33 PM
  4. Installing Clipons
    By spydah in forum Bike Maintenance
    Last Post: 07-24-08, 11:47 AM
