Specifically a bead roller. They look like this:
Or a sheetmetal brake...
Thanks!
Oh boy. What do you intend to use this complicated equipment for? Do tell...
I have both although I lent my brake to a family member. The bead roller is in my shop in Pawtucket, ri. What are you looking to do?
It's for my '69 El Camino. It needs new floor pans (which I can buy) but it also needs some random support pieces (which I can't). I'm talking a welding course now so I'll start with the basics, but I might need some sheetmvetal tools that they don't have at the Artisan's Asylum.
Here is a support panel for a '67 El Camino:
Unfortunately they don't make them for 68-72s, which means I'd have to fabricate something that achieves the same outcome. In this case, it's part of the structure that holds the truck bed to the frame. Mine is really rusty and probably too far gone to save. I'd get a photo if the car wasn't buried under 6' of snow...
I could help you, but that is a complicated enough piece I would have to charge you. For about the same amount you could buy a bead roller. I seem to recall the harbor freight one is cheap, and only needs some relatively simple reinforcement to work well. There are some other choices available for a little more.
Mike Green
LRRS #450 novice
http://www.mikegreensculpture.com
'06 svx550
'04 cr500 af le
'04 525 smr
'02 660 sms
'01 drz 450 sm streetbike
'99 r7
'99 sv650
'86 rg500
Edit: Bah, got the year wrong... never mind.
They used to sell one.
WFBR6 - Woodward Fab
I have never used this one, but have heard decent things about Woodward fab. It is very similar to the one I have.
Better quality tool, perhaps?
Baileigh Bead Rollers | Baileigh Industrial
The Woodward one doesn't look too much different than a Horror Fright one, which are known for lasting for about 1/2 of your first operation.
