Results 1 to 20 of 20
Went to Keyless Ignition
    Member turbo's Avatar
    Aug 2012
    Western Mass
    Got rid of the key on my bike. Now I don't have to worry about losing it at the track.
    This is a small win for me because I'm not that great with electrics, I always have bad luck. So for it to work first shot. Feels good.
    Went to Keyless Ignition-keyless-ingition-jpg
    Re: Went to Keyless Ignition
    Some kind of fob, or just direct connect?
    Aug 2012
    Western Mass
    Directly connected.
    Posting Freak khuygie88's Avatar
    Dec 2009
    RI/VT
    I have done zero research on the topic but feel like this is a potential solution for my sumo if its affordable ( I used a krypton it's u-lock on my last xr650r) a are to share more details?
    Aug 2012
    Western Mass
    I just wired it to start regardless. There is no "key" anymore anyone can start it. Now I don't have to worry about loosing the key.
    Wirelessly posted
    You have a battery charger, right?
    Member yzedf's Avatar
    Feb 2006
    W Greenwich RI
    Toggle?
    AM #152 tropicoz's Avatar
    Apr 2010
    Maine
    Wirelessly posted
    This guy is giving you a valuable tidbit! I had a keyless ignition on my GSXR, but the battery would drain if the bike sat unridden for more than 4 days. I'm assuming yours is a track/race bike only? If so, save yourself the hassle and disconnect the battery between outings.
    Quote Originally Posted by tropicoz View Post
    Or put in a toggle switch.
    Wirelessly posted
    Quote Originally Posted by csmutty
    Bipity-bam!
    Also make sure there isn't supposed to be some seen resistance from the ECU if not you may have to put in some, as it will run like Poop in limp mode....
    Here read this just in case......its a 100Ohm resistor but I would throw a meter on it just to be sure.
    http://forums.13x.com/showthread.php...hlight=keyless
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    The hot set up is to get a toggle style kill switch off of a kids dirtbike and put it on the left handlebar where your switch gear used to be.
    I didn't click the link... but the issue sounds like the one where you remove/jump the clutch switch. That's the one that retarded the fuel/timing map (don't remember which). I will give a read when I'm not at work, but would be surprised if the ignition did the same... Related to being in N / having clutch disengaged. Good looking out either way piggy!
    Yup its similar dif resistance I think but last year I made the mistake of removing the clutch switch and tied them toghether but it works and runs and drives as it seems......then its way down on power, fixed it and she ran as it should. FUGGIN Limp mode in the ECU sucks ASS
    Lake Champlain, VT
    I ran a full weekend like this... I went from an '03 Gixxxah running 26's one weekend, to the '06 running 24's on 60% power the next weekend... Think I made it down to 18's that first season (at full fuel/ignition).
    On a positive, when running at 60% power, it IS possible to use it ALL.
    Aug 2012
    Western Mass
    Yeah I put in a 10W 100ohm resistor and the regular kill switch functions as the toggle switch so far i have had no issues.
    Lake Champlain, VT
    Quote Originally Posted by turbo View Post
    Did you modify the harness passing through the OEM toggle?
    Good deal just didn't want you to get to the track and find out this info.....as I did the Hard way
    Aug 2012
    Western Mass
    I jumped the wires that I needed to. but its all reversible i didn't cut any wires.
    Lake Champlain, VT
    Interesting... that's trick! As is, ignition "on" but kill switch "off" still draws current (as mentioned above). No experience giving the OEM throttle switch gear double duty. good deal!
  1. Wanted - Motorcycles | WTB: first gen sv650 keyless gas cap
    By Johnpewpew in forum Wanted
    Last Post: 03-06-19, 02:30 PM
  2. Keyless Gas Cap
    By JettaJayGLS in forum General Bike Related
    Last Post: 08-18-15, 09:33 AM
  3. Keyless gas cap project
    By jcbell1007 in forum Pit Area
    Last Post: 03-28-13, 06:16 AM
  4. wtb 1/4 turn keyless gas cap
    By catch2otwo in forum For Sale
    Last Post: 12-04-09, 10:05 PM
