Hey, guy's I need to buy a new battery for the gix. can anyone tell me which one will be a good battery to buy? granted I don't want to spend megabucks for one either.
Yuasa AGM
I may have one in stock for you if you're in close to Watertown, MA.
If you have a GSXR600 '97-'07 I can have an AGM ready within 2 hours.
617-264-0531 10am.-2pm. Sat.
I also just purchased one of the Bikemaster Tru gel's and I have no complaints so far. It was $109.00 for an R1 so I'd imagine you could get one for much cheaper for a 600.
How much are the Bikemaster Tru gel's??
I have to look up true gels, but the agm yuasa is a little under $100 .
Sent from my PC36100 using Tapatalk
Call 10am.-2pm. Sat. To get exact prices. 617-264-0531
If you have a Batteries Plus near you, they've been pretty good on price, I've purchased two from them with no issues.
Yuasa YTX9-BS AGM battery in stock - $78.95
BikeMaster TrueGel - Special order 1 business day - $71.95
I see how it is...
Get the Yuasa...they are the best in my opinion. My VFR's cost an arm and a leg at close to $180
Yuasa AGM... foolproof! The best $90 I've spent on her so far.
My little Cagiva has a weak charging system, so I keep her on the smart tender most of the time. No worries about overdoing it. Fires right up at nearly 15 volts... big spark and fast starter rpms.
I'll be getting one for my VFR next month.
PK
1985 Cagiva 650 Alazzurra, 1992 VFR 750
Our info and hours are here: DUNCANMOTO
Give me a call Monday 2-7pm. with a credit card and I'll activate the battery for you. It's a 2 hour process with a 5 phaze shop charger.
If you ride out you can change your battery out on the spot. We have tools.
I've always had Yuasa with good luck. I always keep the battery tender on them for the winter and my '02 Shadow still has the original. I replaced the one in my '98 Superhawk three 3 or 4 years ago.
How much for a YTX12-BS/MG12-BS Truegel? My cheapo ebay Chinese battery from last year must be shorting itself out.
All set guy's....it worked. thanks
