Results 1 to 15 of 15
Left over Suzukis
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Left over Suzukis
    Thomas Suzuki Port Jefferson, NY (Bridgeport ferry)
    2006 SV1000 Brand new $ 6500
    2007 Bandit 1250 Brand New $ 6783
    I am buying a brand new leftover 06 VSTROM 1K for 6783 myself
    He is closing, won't last long. mention my name I get a bird dog
    Rich Weir
    631 588 3399
    Glen Beck is John the Baptist
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Re: Left over Suzukis
    Didn't I give you that lead 3 months ago ?
    TIMMYDUCK
    Aug 2004
    Baltic,CT
    Damn oldtimers disease
    Aug 2004
    Baltic,CT
    BALLS
    My son was up all night throwing up and no one else to watch him
    so i CAN'T GET THE VSTROM TODAY
    hope it doesn't queer it
    Feb 2003
    Quote Originally Posted by richw View Post
    BALLS
    On my way to Baltic if you need me.
    TIMMYDUCK
    Aug 2004
    Baltic,CT
    The guys says OK
    I will be getting tomorrow Saturday
    Thanks for your support
    Aug 2004
    Baltic,CT
    So Far So Good
    WOOT
    There is what appears to be a brand new
    06 Vstrom 1K in my Van and I have a Suzuki Certificate or Origin signed to that dealer as a sub of Thomas Dodge.
    He still has the SV1000 for 6500
    Rich, suzuki was still having occasional ECU problems in the beginning of the mfg. year, but corrected by the end of 06, you may or may not have a bad one, but afik, suzuki has been good about replacing them
    Aug 2004
    Baltic,CT
    woot no WON'T
    well wilt
    ha ha on me thanks God
    she wouldn't start today.
    plugs are fouled plus I am sure the gas is 4 years old
    It did idle rough yesterday.
    I am gonna get some iridiums and drain the tank and see if I can purge the pump
    I also will see if i can purge the injector plumbing as for all I know it has water in it. From the fuel filler everything looks clean and pristine.
    Doh !
    This is because I posted I never bring a bike to a dealer
    Aug 2004
    Baltic,CT
    SAGA Over
    pair of denso iridiums, new gas, new oil
    varoom
    Rich, DL1000s are known to need TBS right out of the box
    Aug 2004
    Baltic,CT
    Randy
    did you do the rear sprocket modification?
    Randy
    um yea, I did a sprocket modification, but not the "2mm off set to correct the eom misalignment" I think that was a hoax
    what I did do was convert to 530 after I wore out the oem 525
    I'm running a Suzuki oem SV1k front sprocket (17t), generic DID o-ring 530 chain and Sunstar 42t steel rear, only got 16k out of the original 525 with a scottoiler, 32k SO FAR on the 530, but I just replaced the front sprocket, and experiment to see how long the chain & rear will last if I only change the front (my riding style eats front sprocketsit did on my SV650 as well)
    I also drilled an inspection port into the front sprocket cover
    Aug 2004
    Baltic,CT
    I guess I will be hoaxed cause it looks like the chain is riding on the side of the rear sprocket.
    My brother has an early 04 with stock 525 and went up to a 530 as well with a substantial re gearing (that I don"t believe in) If yoiu want passing power just ride around in 5th or 4th
    With monsoons comming I don't think I am on the road till next week espescially if I get some work
    A little pleased that full 500 ded coverage was only 276
    sounds like there is some inconsistency, cause the way some people talk, the rear sprocket is out of line, but more often, no problems
    I'm not much for changing gearing either but I did go up 1t in the rear, I still don't get into 6th unless I'm on the highway cruisin @ 80+
    fwiw, 4th is the strongest gear, its the only gear that is unrestricted throughout the rpm range, 1,2 & 3 are restricted to meet noise requirements under acceleration, 5 & 6 are restricted cause the engine is too much for the frame, the bike is unsafe over 130 or so, you can probably go faster, (maybe 135-140) in 4th
  1. Anybody left?
    By Mr. Gixxer in forum Rides & Events
    Last Post: 01-21-11, 09:58 AM
  2. Rumor mill: no 2010 Suzukis (except MX)
    By markbvt in forum General Bike Related
    Last Post: 10-03-09, 11:34 AM
  3. Left my key in it!
    Last Post: 05-15-09, 08:21 PM
  4. One Hat Left...
    By Stoneman in forum Storefront
    Last Post: 01-05-07, 11:22 PM
  5. Official 2004 Suzukis, Now Online
    By jsven007 in forum General Bike Related
    Last Post: 09-13-03, 03:57 PM
