i have an 04 buell xb12s and i just lost my only key. i'm totally f@cked!! any advise??
You could remove the lock assembly and disassemble it. Remove the tumblers and use a blank Buell key. Not the best.
Or
You could remove the lock assembly and disassemble it. Noting where the tumblers are you could CUT (not copy) a new key. It does take a special tool.
Or
You could buy a lock assembly with a key from Buell
In the words of Robin Hood. Call the locksmith.
Go to a Harley dealership with your title and I think they can get one made.
Or go on eBay and buy a ignition & key.
04 XB12R
02 CBRF4i
BearsDen.com
Buell was your 1st mistake.....![]()
Call up a locksmith first. If they can't help you, dealer. Manufactures have different methods of keeping a "key code". Some dealers keep it in your paperwork. Sometimes its on a tag that comes with the master key, and sometimes there is a string of numbers punched into the side of the ignition that you can see once you pull it. On my fzr I just had to pull the ignition and bring it to a locksmith and I had a new key the next morning.
I think I'll call locksmith and dealer to see what they can do first.just bought the bike. Already ordered 2 blank keys for it. But lost the only key.
That sucks! I have 6 spare keys for my R1
Hell yeahhhh!! Found the damn key 8==>. Somehow it ended up under the dryer. Thanks all for your advises. I'm going to copy 3 more keys.
Do it today. Don't wait at least get one spare today.
A related story here. A friend was visiting some relatives up here in Massachusetts. He was from Florida. He locked the keys in the car trunk. He gave me a call. I had his wife send up a picture of her key and we got a blank at the hardware store. I cut (not copied) him a new key with the blank.
Key cutter :A portable hand-held device for code cutting notches in a key blank by a punching mechanism permits quick and easy modification to accommodate key blanks of different configurations and keys requiring different notch depth, notch spacing and notch angle. A key-gripping vise slidably held by a carriage moves transversely to the punch to achieve proper notch spacing. The carriage is controllably moved to different heights above the punch by detents in a circular drum, whereby the depth of the notch is determined. The punch rod and matching anvil may be replaced to achieve a different notch angle.
I have a 3 key policy
#1 key gets taped to the vehicle paperwork and resides in a file
#2 key goes on my key ring attached to a chain the other end attached to my wallet.
#3 key is copy and is key that gets used regularly
Where are the pics of this bike??? I like these!!!
i had quite of bit of ignitions in this spring from people losing their keys over the winter, spares are your friend.
.:|LaRNZ|:.
bring the ignition to a locksmith with a blank
