Results 1 to 25 of 34
I love me a twin.
    I love me a twin.
    Just picked up a 97 Suzuki TL1000S. Gawd this bike has a shit ton of power and when you crack it open the sound and pull just force a smile. It is in great shape for the year. The only concern I have is that this bike is going to be used at NJMP and it seems like some wind protection would really aid the bike when at those speeds as it forces your helmet back and you really have to work to keep your head forward. The full fairing did come with the bike but I am just wondering if there is any way to keep the fightered look and still redirect the wind. Anyways, here are the pics.
    Todd Twheat18's Avatar
    Stow, MA
    Re: I love me a twin.
    cool bike man! I bet those Leo's sound real nice
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    Those rear turn signals made me wince.
    At least it's
    Quote Originally Posted by Twheat18 View Post
    Thanks. Yea they sound realllly nice!
    Quote Originally Posted by catamount View Post
    At least it's
    Yea I am putting some other signals on it.
    Lifer obsolete's Avatar
    Norf Sho
    At least it's
    Looks more like an over flow?
    If it has spray I like it even more.
    -Alex
    Haverhill, MA
    Enjoy the TL bud! tlzone.net will become your friend. My 97 is still a fun bike to ride even 13 years and roughly 60,000 miles later.
    I happen to have a full set, minus the tank, of primer black "track" plastics sitting in my basement that you might be able to borrow for the NJMP days. Looks like you would have a problem putting them on the bike though with that unorthodox location for the steering stabilizer and the lack of the mounts up top around the speedo.
    We'll talk about this stuff up at the track this weekend.
    Joel
    Joel
    Thanks for the offer man! Yea I know I will need a front fairing stay and possibly an air box that has the ram air tubes.
    Posting Freak
    New Hampshire
    TL's are great. Keep an eye on the rotary damper mounting bolts. They can loosen up making the damper move around and crack where it bolts to the frame. Also some frames cracked up by the stearing head.
    One of the best motors in the business
    Feb 2008
    Las Vegas
    TWINS ROCK!!!! Nice pick up bud!
    Carpe Diem
    '10 Yamaha R6-Race-
    Quote Originally Posted by beet View Post
    Nice. Get rid of the rear damper, wahla nice bike..
    Rear damper?
    I like the streefighter look!
    Central VT
    Rear damper?
    The rotary damper that you will eventually replace with a non-piece of shit Ohlins.......
    Going from a ZRX to a TL, who'd 'ave thunk it?
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Quote Originally Posted by Uncle Snake View Post
    Now THAT is creepy!
    You have an ohlins in yours? How much change did that set you back?
    Central VT
    Now THAT is creepy!
    Yeah,you can kinda see it in there...... I think $700 or so.... not exactly sure...
    Jake
    2006 ZX-10R
    That's a nice looking TL! Did the S models come with the lower fairing? Or did you just put it on from an R?
    Lifer 03Worc9R's Avatar
    Worcester, MA
    +1 on the twins.
    I bet that bike sounds nice!
    Haverhill, MA
    The TLS and TLR are pretty much completely different bikes with regards to frame and body work so the belly pan that is on Snake's bike was made for the TLS (It also looks like his uppers might be a bit different then stock). They share wheels, some engine architecture and a few other things but otherwise two different bikes.
    As far as the rotary damper goes, the stock set up was attempt by Suzuki to change/revolutionize how shock absorbers were used. It didn't work out so well and obviously they went back to using standard shocks on future models. That being said, Ohlins made a replacement unit as well as a company called Bitubo and possibly a couple of others, the two most popular are the Ohlins and the Bitubo though. The Bitubo replaces both the spring on a stick, which is the red spring on the right side of your bike, and the rotary damper with a single unit. If I am not mistaken the Ohlins replaces only the rotary damper. The spring on a stick, SOS, is a common issue with the TLS where the rubber bushings wind up binding on their pivot points and causing an annoying squeaking noise until something finally wears through and the SOS actually breaks in half causing some "minor" issues. Keep an eye on it and keep the bushings lubed up. Might not be very easy to find a new replacement shock set up for this bike new as most companys haven't been making new parts for a bike last sold new in the early 2000s, the used market for these bikes is there though so shouldn't be a big deal to find something if you need it.
    As Ryno mentioned, make sure your rotary damper mounts are tight and not moving around and also check your frame up by the head stock as some TLS have had issues in those areas.
    tlzone.net has a ton of information and a fairly dedicated group of individuals with a wealth of knowledge about these bikes and you can find a solution to just about any issue you might have on their board. Not trying to overly plug another board but the people over there have saved my ass multiple times with getting things fixed on my bike without going to a shop.
    Here is a link to the factory service manual http://www.jiffypark.com/tl/TL1000S_Svc.pdf
    Joel
    Last edited by tls25rs; 08-31-10 at 07:33 AM. Reason: added link to service manual
    Norf Sho
    PS twins rule.
    -Alex
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    www.bostonmoto.com
    Forum Rules
    Apr 2006
    Beverly, MA
    Love the bug eyes
    Nov 2008
    Framingham, MA
    "Jack. Twins. Swedish. My place. Now."
    Central VT
    Now THAT is creepy!
    No THIS is creepy..... Here's what mine looked like when I bought it:
    Jake
    2006 ZX-10R
    Central VT
    Take a look here at my TLS folder in photobucket if you're interested. I'd be happy to answer any questions.... My fairings, uppers & lower came from Sharkskinz.
    http://s21.photobucket.com/albums/b2...snake/TL1000S/
    Jake
    2006 ZX-10R
    Very creative, nice stuff. I'm in CT (Wilton) and (MCH) right now for a couple of days, MCH not far from you, actually.
    Enjoy.
  1. My First Twin
    By Kitt in forum General Bike Related
    Last Post: 05-22-11, 07:06 AM
  2. I-4 vs. V-twin
    By GixerJockey in forum Pit Area
    Last Post: 04-05-09, 07:57 PM
  3. The joy of a twin....
    Last Post: 05-06-02, 09:50 AM
  4. The TWIN is IN!
    By cRa1g in forum General Bike Related
    Last Post: 07-31-01, 12:50 AM
