no no, I know you were... I was just mentioning a similar race-derived feature of my bike (the launch light), which I don't use but I can see its utility for actual drag racing.
Now I'm not a track-day kind of guy, but would you ever actually use a lap timer? What trips it? How are you supposed to pay attention to it when you're supposed to be focused on riding?
basically all it is is a bright light on the dash that you can set to come on at a predetermined RPM, for launches. But since I don't drag and I like my clutch, I do Olde Pharte launches, slipping from idle, and thus don't need the launch light. I can see the utility of it though for folks who DO dragrace, and yeah lots of these bikes do spend their lives at the strip.
If you are going to launch your bike at 4K, make sure to remove your electronic sub-throttles so the ECU can't limit your power in the first few gears!
Launching the 14 is intimidating if you aren't used to bikes its size. One thing is for certain and that is it is a hell of a lot easer than launching the 12R which sits higher, has a shorter wheel base, and a sharper power curve.![]()
'19 KTM Duke 790
'18 Aprilia Tuono Factory
If you look down, you go down. That may be fun at an orgy, but it sucks on a bike
I've still got my secondaries in... I'm satisified with the stock power delivery. 50+ ft.lbs. just off idle is plenty for me.
Yeah I'm pretty much used to bikes this size; I've got 28,000 miles on my ZZR1200, but I'm not used to high-rev drag launches, simply because I don't do it. I do agree with you comment about relative ease though vs. shorter, higher bikes like the 12R or litre bikes due to the favorable geometry.Launching the 14 is intimidating if you aren't used to bikes its size. One thing is for certain and that is it is a hell of a lot easer than launching the 12R which sits higher, has a shorter wheel base, and a sharper power curve.![]()
I've always loved the 12R... lusty bike.![]()
Muhammad Ali.
mine has a little thing called an odometer and a reserve tank. i dont need no stinkin gas light
Tuono
