Results 26 to 50 of 60
Ninja 250 motor transplant... what motor to use?
    Senior Member B440's Avatar
    Jul 2012
    Thompson, CT
    Re: Ninja 250 motor transplant... what motor to use?
    Quote Originally Posted by DynoTune View Post
    well, the cr250 coil can be converted easy and a dc regulator added, I do it on the banshee's. use a ignitech programmable ignition, super simple starts with spark on every kick... I did the same on my cr500 power streetbike.... it did start a whole lot easier.... ever try to start a cr500 engine stock?? my god!
    use led lights to save power.... I never had an issues with low batteries....
    ex500 engine....kinda boring....I think... Ill checkout the trx250 motor, forgot about that one! I was picturing it in my mind as I had checked it out before but could not rememeber the name.........Thanks for reminding me!!! I am pretty sure they are tons around, tons of parts as well....going to see if they make as much hp as the cr250....
    Yes. As much power, easier to get higher wattage for lighting, counterbalanced, 6-speed. Tons of upgrades; 310 powervalve, etc. This is the way I'd go. The only thing missing would be oil-injection like the RZ350's had. I'd like to have the trx engine in an 08+ ninja frame.
    The CR250 and CR500 just don't have enough room under the left-side cover for proper lighting.
    I've had two CR500's, an 89, and a 97. Easy to start when tuned properly. Cold starting required "the method" but once they were warm, I could kick-n-go like a 250 as long as I wasn't lazy about it
    Jul 2012
    Thompson, CT
    Yes. As much power, easier to get higher wattage for lighting, counterbalanced, 6-speed. Tons of upgrades; 310 powervalve, etc. This is the way I'd go. The only thing missing would be oil-injection like the RZ350's had. I'd like to have the trx engine in an 08+ ninja frame, or a CBR250 frame.
    Two many 2 strokes
    Bradenton FL
    im short....after trying to kick my cr500 engine tons of times, I gave up.... new 12vdc ignition... started so much quicker
    Jul 2012
    Thompson, CT
    The two bikes I owned did have the factory scallops over the exhaust, which made it easier. The older bikes and any bike bored out to max would be a lot harder to kick with full compression. I had a decompression valve installed on the 97. I could start it on the side of a muddy hill with the kicker facing the hill. Best mod ever
    Some ignitions were better than others. Mine never gave me issues. I hated the stock carb. Switched to a PWK and it finally idled longer than 30 seconds and started easier when cold.
    Two many 2 strokes
    Bradenton FL
    well, i put the cr250 motor in place..everything looks good to go. Fabed the motor mounts up. I should have it bolted in tommorrow if all goes well..Dam, this bike is going to be light! Ill post up some pics
    Two many 2 strokes
    Bradenton FL
    Ninja 250 motor transplant... what motor to use?-dsc02831-jpg
    Ninja 250 motor transplant... what motor to use?-cr250_motor-jpg
    Ninja 250 motor transplant... what motor to use?-cr250_side-jpg
    working on the pipe now...I keep pulling parts off..getting lighter and lighter.. to funny...
    Jul 2012
    Thompson, CT
    Exactly how much of a kit will you be making? Just the motor mounts, or the longer radiator hoses, and a pipe?
    Sep 2011
    Peabody, Ma
    I kinda want to ride that.
    07 S4RS
    I really want to ride that.
    Raymond NH
    There's a big piece of structure missing between the steering head and the swingarm pivot.
    Ninja 250 motor transplant... what motor to use?-build_cleanframe-jpg
    I don't think this frame was meant to work without the engine, or some other structure, tying the bottom of the steering head to the swingarm pivot. Without that, the stress on the remaining frame is excessive. I think you need a pair of tubes under the engine.
    Two many 2 strokes
    Bradenton FL
    Yup, there will be a cradle under the engine going up to the top. For testing, this will be just fine This is the basic test bike... mostly dyno time not alot of street riding. Once we feel this works well, we will buy a 2010 modern 250.... new body style....
    We will fine fit what we have learned on this bike to the new bike as the motor is the same.
    Im not sure about a kit....I know we will make the whole thing a bolt on deal.... We might just buy the bikes at auction and do the conversions in house.
    The kit would include
    Custom Pipe
    motor mounts
    custom kick start lever
    Programmable ignition with 12vdc battery
    12VDC coil/regulator
    shift linkage adaptor
    lets see how this one works first Working on the pipe today. Ive made some 2 stroke pipes before....not fun... I need a company to make me them so it will be a while before we can get that moving...
    Two many 2 strokes
    Bradenton FL
    Got the pipe mocked up...its going to fit perfect... does not hit the body at all. It does sit just a tad low but thats because the pipe is massive...nice little 2 stroke bulge.... I should have the pipe welded up early next week... I need to document the pipe first so i can make more just in case ill post up some pics once mounted... looking sweet!
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    How do you make sure the pipe designed is right? Is there some sort of formula for the design?
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Two many 2 strokes
    Bradenton FL
    well, in the past ive designed using two stroke software that prints out paper as a templet. Since im just doing R&D I simply use a stock pipe, cut it up and rotate the sections to make it work. Keeping in mind to not change the length. This will tell me if I have enough room under the bike for the pipe needed...and its looking perfect!
    Two many 2 strokes
    Bradenton FL
    Got the pipe all done, motor mounted... finishing up the coolant hoses. chain, throttle etc... its fitting all real nice! Lets hope the vibration is to not excessive. Top speed looks to be about 90mph.... but it should get there quick! The bike weight right now is 275lb and with 45hp....should go just fine
    stay tuned!
    Ninja 250 motor transplant... what motor to use?-dsc02990-jpg
    Ninja 250 motor transplant... what motor to use?-dsc02992-jpg
    #331 CBR929RE's Avatar
    Bridgewater, MA
    needs a new case cover.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Nice...
    Now build one with a Rotax 670 twin 2T....
    Lifer Stromper's Avatar
    Eastern Ct
    Banshee
    The calculus of hate
    Feb 2012
    I didnt think the quadzilla was counterbalanced.....Thats why i opeted for the cr250... I put a cr500 in a streetbike... I did the best build ever for this attempt... just to much vibration, even with custom fully isolated rubber mounts.... the body cracked, mirrors rattler bad...dont get me wrong, I could have continued to work on it but it just sucked to much.
    Attachment 36995
    Attachment 36996
    then converted to a 115hp banshee motor
    Attachment 36994
    banshee was the way to go.... smooth and fast!
    The rd motors are to low tech... plus they have 2 cyls/ pipes... trying to make it light.
    The cr250 has 48 HP....the stock 250 ninja had 24hp.... I have a cr250 motor now... im leaning this way heavy as I can get cr250 motors everwhere cheap. The quadzillia motor is very hard to find.
    Someone probably answered tihs already. But all of Suzuki's 2 stroke race quads were counterbalanced.
    OP, go a GT750 or H1 motor
    Too many bikes to list
    Mosdt likely drunkd
    Jul 2012
    Thompson, CT
    I bet Garret could hook you up with lots of cheap Suzuki LT250R quadracer engines. Plenty of those around, counterbalanced, lighting coil, etc.
    Feb 2012
    Hahaha! I got out of the Quadracer game a couple weeks ago. No more 4 wheeled off-road machines for me. They're all way to beat to be worth flipping.
    Mosdt likely drunkd
  22. #47
    Two many 2 strokes
    Bradenton FL
    the cr250 engine is so main stream with all the shift cart racers....tons of parts.
    An h1 or h2...my god...3 f-in pipes under that bike... it barley fits one big CR pipe LOL.
    Eastern Ct
  24. #49
    Jul 2012
    Thompson, CT
    The Banshee motor has been done before.... by Yamaha. The RZ350
    Ninja 250 motor transplant... what motor to use?-rz350studio_small-jpg
    Lifer JohnnyV's Avatar
    Westborough, MA
    stay tuned!
    Is ground clearance on right-hand turns going to be an issue? From the pic it looks like it might
  1. Ninja 250 motor vs. clutch grenade?
    By feralchimp in forum General Bike Related
    Last Post: 09-17-13, 09:27 AM
  2. ninja 2009 motor upgrades
    By fjrrider RI in forum Bike Maintenance
    Last Post: 10-20-10, 09:50 AM
  3. So, I need a motor
    By Tricky Mike in forum Bike Maintenance
    Last Post: 11-16-09, 08:01 AM
  4. FS CBR F2 MOTOR
    By Devil1 in forum For Sale
    Last Post: 09-29-09, 06:26 PM
