Results 1 to 25 of 29
Oooo LOOK! another oil thread
    i havent had to mix gas with oil in some time. and when i did it was leaded sunoco 110 octane and Torco for my goped.
    i looked through my catalogs at work and it seems that parts unlimited doesnt carry torco. so now i dont know whats good and what sucks. generally i would say oil is oil and whatever i get will be fine. i even looked through my owners manual to see what KTM recommended but didnt see anything right away but ill keep looking.
    so as with any oil thread ill ask "what do you guys use?" and then watch you all bicker like old ladies.
    commence!
    I93/495
    Re: Oooo LOOK! another oil thread
    Olive. Extra virgin.
    Mixed 1:1 with vinegar?
    2013 ZX6R-636
    Meriden, Ct
    Anal-Ease... that shit can lubericate anything.
    lubericate
    thats some hooked on phonics spelling right there
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Used Mogul synthetic in my 300 exc mixed around 45:1. Never fouled a plug in 8 years, and it looked great when I tore it apart.
    i assumed you meant motul
    Member z3dsp33d's Avatar
    Oct 2013
    Amesbury, MA
    Oils:Gotta catch em all.
    http://www.spectro-oils.com/platinum-sx-321/
    At 50:1, still running my original plug, minimal spooge out the tailpipe. More like residue than spooge.
    Follow the oem jetting recommendations, and you're all set.
    I'm running BelRay H1R at 40:1 in my WReck. I've heard a few different people running 50:1, may try it, but for now even though I smoke a bit more I like the comfort value of knowing there is plenty of oil around the crank and piston.
    bike has a jet kit in it. not sure what though
    i agree. ill take smoke fro the peace of mind. i ran my goped at about 28:1 but the torco oil is smokeless and it did a good job of it too. i need to search the owners manual some more. otherwise im gonna run 32:1
    The standard for the 300 is 50:1. So Todd's 45:1 should give to the extra piece of mind.
    I ran 32:1 Spectro because I'm extra slippery like that. I'd say you can run the 45:1 or 50:1 without worry. They all know what is the best ratios to use so just follow what the bike MFG says. If you are concerned, just go a little richer.
    I run Spectro or Suzuki branded 2 smoke mix. Only the latter cause it was cheap and I bought 4 quarts of it. Works great in everything that goes RING A DING DING DING DING in my garage.
    If you richen the fuel oil mix don't you lean the air fuel ratio, iirc? If so just remember to jet properly if experimenting with premix ratios.
    2013 ZX6R-636
    Member MikeP's Avatar
    Jul 2012
    Killingworth CT
    +1 I've always done the same with my CR125 and it runs great
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    KTM recommends Motorex, which is what I'm currently using in my KTM 250sx. I've used Maxima as well.
    I'd be curious to know what my bike originally called for, although that'd be based on 20 year old oil tech so really not all that applicable now a days anyways. Belray says 40:1 for their H1R on machines larger than 125cc so that's what I used as a starting point.
    BITS: Yup, more oil with no carb changes results in a leaner mix.
    Amsoil Interceptor (trail) or Dominator (track) here. 44:1. Interceptor has a lower flash point so better for slow woods plunkin'.
    jetting and power valve maintenance are an important part of the equation. silencer packing too.
    When I first got my KTM, I used Motul 800 2T at 60:1
    I switched to Golden Spectro and still run it at 60:1.
    With both oils, I still get some goop out the pipe..even at 60:1...but I blame that on myself for riding slow and having trails that don't often let you get out of second gear. Never fouled a plug..in fact, my bad, I have never even changed the plug yet
    Old and Slow Sheppo's Avatar
    Westford, Ma
    I like Amsoil interceptor
    Posted by Jane in BoxChat
    Banned G21forme's Avatar
    Lakes
    Whale, baby seal, and if you can find it koala bear it the best.
    Sent from my SCH-I535 using Tapatalk
    #331 CBR929RE's Avatar
    Bridgewater, MA
    do you hug the Koala so tight to get it?
    I used the suzuki 2-smoke oil when I had one...
    which size jets are inside the bike, which temp will you be riding, and what elevation?
    We tried many oils in our 200hp. V6 two stroke outboard, because you go through gallons of the stuff. We entually bought nothing but Yamalube. We added Ring Free or Techron due to the relatively poor fuels available.
    The 2S grade is sold at Yamaha marine, West Marine, and Yamaha Motorsports dealers.
    http://www.yamahamotorsports.com/out...09/detail.aspx
    Others swear by 2R, because Racing.
    http://www.yamahamotorsports.com/spo...61/detail.aspx
    Meriden, Ct
    WHAT?!? 28:1???
    I'm about to start riding my goped... (I know... a little late) Does that thing really need that much oil? I was about to run it at 50:1
  1. NWS jro thread
    By a13x in forum Site Info & Suggestions
    Last Post: 09-14-09, 03:52 PM
  2. DON'T POST IN THE "DON'T POST IN THE 'CHIC' THREAD" THREAD
    By Honclfibr in forum General Bike Related
    Last Post: 10-11-07, 12:05 PM
  3. Daytona Thread planning thread
    By Degsy in forum Pit Area
    Last Post: 10-05-03, 07:04 PM
