Results 1 to 7 of 7
paging gino
    soldier medic neuthunder's Avatar
    Jul 2005
    boston/abington
    paging gino
    you going to be around at all this week? the hawk sat all last week while I was on vacation and went to start it today and things aren't looking so good. I pulled the carbs and cleaned some gunk out but It still idling rough and I think the throttle might be stuck.
    Re: paging gino
    Stuck throttle?
    damn ethanol
    If you had junk in your bowl check out the pilot jets.
    Throw in some dry gas as well.
    Jul 2005
    boston/abington
    Re: paging gino
    pulled the carbs apart, filter in the float bowl had gunk, cleaned the jets.... i think it might be the cable or something, I have the idle adjustment turned down to the point where its not touching the throttle body but its still idling a little high and bouncing a little. I'm gonna get it out for a run and try to burn all the gas in the tank and put some fresh gas in, I'll update in a little while.
    Re: paging gino
    Choke is stuck somehow. Check the 1 into 2 housing and make sure nothing is pulled out slightly.
    Jul 2005
    boston/abington
    Re: paging gino
    ok definitely the choke... something's up with the cable, i'll check that 1 into 2 housing but the choke lever isn't doing a damn thing when it's opened or closed so something separated
    Jul 2005
    boston/abington
    Re: paging gino
    ok then the 1-2 was not together... which is now together and she's running fine. You around this evening? I still want to bring her by to show off the new exhaust.
    Re: paging gino
    I'm available to 6:30 cruise on by.
  1. what oil does Gino use?
    By Jim in forum Bike Maintenance
    Last Post: 12-05-13, 12:11 PM
  2. Gino!!
    By s a x m a n in forum Pit Area
    Last Post: 10-10-06, 10:21 PM
