Results 1 to 8 of 8
Paint stripper?
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    Paint stripper?
    Does anyone what I could use to strip a piss poor paint job on factory panels without wrecking the integrity of the panels?
    Aircraft stripper I'm assuming would be to harsh? Some had suggested oven cleaner?
    Here a link if you don't already know why I'm asking:
    http://www.nestreetriders.com/forum/...new-paint.html
    Lifer Wishbone's Avatar
    Jul 2006
    Re: Paint stripper?
    Perfect way to paint a stripper.
    Re: Paint stripper?
    Don't strip it sand it down there fore you are able to do it with out blowing thru the plastic......and any stripper will melt the shit out of them...
    Dec 2008
    Framingham
    Re: Paint stripper?
    Hmmm, the few paint shops I have talked and recieved emails from all said they would "chemically strip" the panels?
    The reason I don't to sand is I have a sneeky suspicson that the bike had some sort of vinyl graphics on it before it was painted. Which is causing the rough paint.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Paint stripper?
    There is no guarantee the plastics are the same for each piece and will/not restrict the plastic melting from stripper.
    I had good luck with the ready stip paste
    Put it on cover with plastic come back in 4 hours and see
    You might try an epoxy or kilz type primer that would form a barrier layer to paint below.
    Glen Beck is John the Baptist
    Lifer Pittenger5's Avatar
    Austin
    Re: Paint stripper?
    Quote Originally Posted by richw View Post
    Id sand. I'm sure theres plastic safe strippers, but when I had to do my bikes I sanded. If you use a medium-coarse sandpaper itll take off the vinyl, then switch to a finer grit to smooth it out.
    Zip Tie Alley #505
    Lifer DuncanMoto's Avatar
    Re: Paint stripper?
    Ive used chemical stripper on plastic with no issues. The finish was crap underneath, but that's due to sanding the plastic before in prep for primer.
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Paint stripper?
    Brake Fluid?
  1. where do i get 08 SV650s paint dark blue paint?
    By Hauptman in forum General Bike Related
    Last Post: 09-03-08, 03:04 PM
  2. Good Paint Shop for simple paint work
    By hohum in forum General Bike Related
    Last Post: 05-01-03, 01:34 PM
