Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
PCIII by dynojet??
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    my bike runs like shit
    with out the pc installed
    i had 2 try it boy did i go home & hook it back up
    pop & stall
    www.bostonmoto.com
    Forum Rules
    Freak Posting snowborder's Avatar
    Mt. Wannahuckaloogi
    PCIII by dynojet??
    I know that on some Suzuki's the bike has to be running to load a new map. Shut the bike down completely and reboot it. So maybe the same on Yam?
    2001 RC51!!!
    2007 Husky SMR 510 - no longer... blown tranny
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    PCIII by dynojet??
    my bike ran like poop then died with the PCIII installed...i am hoping that the wrong map was the cause...I unhooked it and it's fine..
    Oct 2001
    Bedford, MA
    PCIII by dynojet??
    Originally posted by R7
    I brought it the dealer and they installed the map for me, seeing I bought it there they said anytime I want to change the map, bring it in and they will hook it up. They don't have a laptop but they do have this crazy long USB cable and I don't even have to unload the bike from my truck.
    Mine is the PCIII usb and it is not for a streetbike, it's for my quad. The EFI system isn't quite the same as a streetbike and from what I've read and been told, it's a closed loop system that doesn't self adjust, there is also no O2 sensor. The difference having the PC hooked up even stock with a stock map is huge on this thing. I just put on a slip-on and will be making a airbox mod so I will have to change the map again
    Quad = Open loop
    Most bikes = Open loop
    Some bikes = Semi-closed loop - e.x. medium throttle at 4000-5000rpm "cruise"
    Cars = 100% Closed loop
    Glad it's workin out for you... the PC3 was the best thing I ever bought for my bike.
    "Semi-Closed-Loop" with O2 sensors, etc respond best to the PC3 as these are the hackish solution to meeting EPA regs.
    The new Triumphs are closed loop like a car and they are much better... really smooth while still meeting the tough regulations.
    Sounds like the new R6 is probably closed loop too?
    Lifer ZX-12R's Avatar
    Candia, NH
    PCIII by dynojet??
    I doubt any fast revving engines have a completely closed loop system. The cpu is plenty fast enough to respond to changes, but I don't know of any O2 sensors fast enough to work in a closed loop system. If the engine is at cruising speed or under very light acceleration then it is possible but when you blast through first gear in 4-5 seconds, it is open loop all the way.
    PCIII by dynojet??
    Quad = Open loop
    Where did you get this info, are you guessing or do you have facts? I read some tech details saying the quad has a closed loop system
    Lifer Currently's Avatar
    Ooltewah, TN
    PCIII by dynojet??
    I really doubt you have a closed loop.
    A closed loop system has sensors all over the place.
    You have the O2 sensor in the manifolds and exhausts.
    Closed loop means that the computer requires feedback
    in order to set the ignition and fuel parameters.
    Open loop means that it has a predefined table and
    when in a specific area of the table, it will do exactly what
    is mapped there.
    So check the owners manual and see if they have any
    sensor maintenence scheduled in.
    We are going to start seeing closed loop systems when
    we have anti-pollution equipment on bikes and quads.
    I think only the Beemer has closed loop right now ...
    not sure but that is what is sticking in my head.
  1. Wanted - Parts & Tools | DynoJet QuickShifter Pull Sensor (for PCIII)
    By dhawks in forum Wanted
    Last Post: 03-08-15, 05:12 PM
  2. Power Commander PCIII vs PCV
    Last Post: 09-12-13, 12:58 PM
  3. Having an issue with my PCIII
    By hefdukes23 in forum General Bike Related
    Last Post: 08-29-09, 12:58 PM
  4. Best Price on a DynoJet PCIII?
    By mikem317 in forum General Bike Related
    Last Post: 08-06-05, 07:07 AM
  5. PCIII For Stock Bikes
    By HBerry in forum General Bike Related
    Last Post: 03-10-05, 08:33 PM
