Results 1 to 25 of 44
Phone Charger for bike.
    Lifer obsolete's Avatar
    Norf Sho
    I've been using the droid as a GPS (kinda) for the bike and was wondering if anyone has found a good way to hard wire mini-usb as opposed to using a lighter converter and thena phone charger line. A quick connect near the seat mid line would be key too. Am I going to have to make this or is there a compnay I can't find doing it.
    -Alex
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: Phone Charger for bike.
    I went to radio shack and bought a cig lighter jack and wired it into my tail section... works well to just charge my phone on longer rides with a regular car charger. I can't imagine it would be hard to wire something up.
    alex, i have one in my bike. very easy to set up. i can show you sometime what it looks like on my bike if you're interested
    Norf Sho
    That's what I wanted to move away from. I'd rather have a mini usb directly wired so I can run it right to the phone. But thanks for the help guys.
    -Alex
    ya sorry. i have what Ryan's got on my bike. if you need a hand with whatever you end up getting, let me know.
    rrrright down by da beach island boyeee's Avatar
    Quincy, MA
    yea i was looking to wire up a 12V USB charger as well. initially i was gonna use my power inverter and the AC charger, but that's too much crap.
    08 Triumph Daytona 675, Jet Black w/ Gold
    dirty bike: 2015 KTM 250 XC-F
    Norf Sho
    How are the GPS units powered? direct line?
    -Alex
    Just Registered drop's Avatar
    Bradford, MA
    http://www.powerletproducts.com/
    powerlet carries direct wire mini-USB cables, along with all kinds of other quick connect sockets/plugs/mounts.
    - Jamie
    2009 K 1300 S
    Norf Sho
    Boomshakalaka Jamie is the man.
    Any sites run by Suzuki people though, you BMW folk double the price of everything. lol
    -Alex
    Quincy, MA
    i think i'm gonna buy something like this: http://www.dealextreme.com/details.dx/sku.15618
    then just break the cigarette plug open, and wire it directly to the battery. then i can run the cord under the tank and up to the mount
    Norf Sho
    Quote Originally Posted by island boyeee View Post
    That was my other plan, but how will that work with bike voltage and what not and which wire should be the power and which the ground?
    -Alex
    Bradford, MA
    it'll work fine with no voltage issues if you grab the wires right at the contacts inside the charger's plug.
    the wire that goes to the center pin on cigarette lighter plugs is always positive, and the one going to the ring is ground.
    - Jamie
    2009 K 1300 S
    Quincy, MA
    ^ beat me to it. one normally has a fuse as well (obviously the positive)
    Feb 2010
    Southbridge
    if you have the car plug usb charger i can hard wire it for you. pm me if interested
    Norf Sho
    No shit. This may work out ok lol.
    -Alex
    Quincy, MA
    yep. i did the same thing with an old DVD player for my car that only required 12V input. just cut off the AC adapter and wired it straight to the car.
    gonna do the same with my new Seagate media player.
    Norf Sho
    I'm planning on doing for a mount for the car to to hard wire in the charger and audio output.
    -Alex
    Canterbury, NH
    yea busting open the plug and hard wiring the wires was kinda what I was leading to when I said wiring it up should be pretty easy. I was going to do that but I figured I could just bring my car charger with me if I wired up the outlet, instead of buying another one.
    Just Registered
    Is it not obvious?
    Just fyi...your Droid is running microusb not miniusb, just in case you use anything other than a regular plug-in charger.
    I would recommend if you do this (hardwiring a regular car charger) I would do it with an OEM charger unit as they typically have the best power conditioning circuits over the other generic units.
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Quincy, MA
    except if you're hard wiring it, you will lose whatever circuitry they may include...
    Senior Member Subee13's Avatar
    Feb 2009
    Salem, New Hampshire
    Alex you all set? If not you have a few options of what you can do. I may even have parts if you needed them.
    Just Registered
    Is it not obvious?
    If you do the hack and slash using only the wiring portions - yes, but you could just as easily make use of it right?
    I'm no electronics wiz, I just know the crap is in there for a reason and my Droid cost about three times what my GPS did and I'm sure it's more sensitive to surge/lag.
    Norf Sho
    Not if I keep the circut and just use the outer most leads.
    -Alex
    Quincy, MA
    you might be surprised to open up the OEM unit and find there's nothing more in there than a fuse as well...
    Just Registered
    Is it not obvious?
    Maybe true in some cases. I have an OEM Droid charger split in half on the desk in front of me, it has a few IC's a bigass coil, some diodes, capacitor, etc. multi layer board with some SMT and thru-hole stuff on it.
    Unfortunately for Obsolete, the cord was jacked from this one long ago for a project similar to his. I've just had this thing hanging around for no reason...I knew there was a reason I didn't throw it away
  1. Transponder + charger
    By burtonboarder23 in forum For Sale
    Last Post: 07-20-13, 06:17 PM
  2. Phone charger???
    By I8A4RE in forum General Bike Related
    Last Post: 07-28-12, 06:33 AM
  3. I need AMB charger
    By sdog30 in forum Pit Area
    Last Post: 06-08-12, 02:05 PM
  4. Need charger for electric quad/dirt bike
    By ThisBitch in forum Dirty Bastards
    Last Post: 08-30-11, 04:05 PM
  5. Powerstick Phone/MP3 Portable Charger
    Last Post: 04-21-11, 08:13 PM
