Results 1 to 22 of 22
Power commander question.
    <---Thats a nice A$$! EFD 05 1K's Avatar
    Epsom NH
    Im looking into getting a power commander for my bike, i dont really want to buy one new so im looking for a used one. I found a PC2 on ebay for my bike and im trying to figure out the difference between the 2 and the 3. I know the 3's are USB and all that but if i just got an adapter would it give me the same tuning? or am i better off waiting to find a USB one?
    Thanks in advance
    Jeff
    05 Gsxr 1k Black/Silver, Yosh pipe, 8k HIDs, a very big grin
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    Re: Power commander question.
    what year is your bike?
    LRRS Expert #99
    08 R6
    "why tip-toe through life to arrive safely at death?" Tony Campol
    To quote PK, I "went in too hot and ran out of talent".
    I will make this easy as Pie...call this guy give him your bike info and he will map it and send to ya...plug and play..I really wouldn't buy a used one but thats me. And who knows how its maped aslo..
    he is a very large PC dealer and he will steer you right...
    I am sure it will be a PowerCommander3 custome map...
    Jamie @
    http://www.fuelmotousa.com
    Epsom NH
    Its a 2000.
    Pigman thanks for the info and i will check it out! I kind of wanted to try that stuff out on my own to get a better understanding of how it works... but if he can set me up with a good custom map that would be nice!
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Jamie @
    you're such a name dropper
    Posted by Jane in BoxChat
    Srry it was a easy thing and the map was spot on>>>>>> i dunno
    Without actually putting your bike on a dyno and building the map there, the best someone's going to be able to do via the post is somewhat close. If you're going to get a PowerCommander, spring for the dyno time.
    No, you can't get it right either playing with it on your own. : )
    As far as PC2 vs PC3. The PC2 was serial based, the PC3 is USB. They both speak the same language, although the PC3 can run a higher resolution map as well as handle ignition, individual cylinder offset maps, etc. For 99.9999% of people out there, a PC2 will work just fine.
    Personally, given the number of flaked out PCs that crop up, I'd buy new so you have a warranty.
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    I've got a PCII that came off my '00 750 you can have. I remembered when I saw this thread and just dug it up in my basement. FYI, the litter box is overfilled. You can PM me your address or come meet me this weekend if you want.
    Epsom NH
    That would be awesome! Whats it have for a map now?
    you're best bet would be to have it custom mapped from a place like RJ's or Rob's Dyno. I think the PCIII was the 1st series to come with an available USB port to hook up to your laptop.
    Epsom NH
    any idea what that costs kromz? All i have is the slip on right now and im wondering if i do go and get it tuned if i should get a BMC or a K&N air filter? I would imagine that opening it up at both ends and then tuning it would be better...
    if you just have a slip on, and/or an aftermarket air filter, then just use the DynoJet maps listed here.
    if you replace the plugs, then i would look into going to RJ's for a custom map. he ran some specials last year for $100. typically, it's around $300.
    Epsom NH
    What do you mean by replacing the plugs? Putting some iridium ones in or something? I just replaced the plugs about 1k miles ago with stock.
    yea, i was thinking the Iridium IX plugs, but i wouldnt bother now that you just changed them
    Epsom NH
    Ok so with a big thanks to burnham i got a PCII and put it in. I notice a small difference but then again its not tuned for my bike yet. Im trying to get it tuned myself but i am having a hard time hooking up the cable to anything, i bought a serial port to USB adapter and got nothing. Any advice?
    Burnham- what was it mapped for when you had it on your bike?
    Wirelessly posted (BlackBerry Curve: BlackBerry8330/4.5.0.131 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    Only use the dynojet maps. Don't try to adjust things yourself
    Epsom NH
    Well as of right now i can only mess with the buttons on it since i cant plug it in yet.
    Apr 2006
    massachusetts
    Quote Originally Posted by Gixxa750 View Post
    It was mapped for a full yosh system, but it was not a great map. I would send the bike over to RJ's or Seacoast Sport Cycle and have them map it on the dyno for you.
    dont touch the buttons on there. someone did that on here a year ago and fooked something up
    Epsom NH
    So what your saying is i should return all the settings back to where they were right? I moved the low and med rpm's up two clicks rich...
    unless you know what you're doing. the only thing you should be doing with that power commander is plugging a USB cable from it to your laptop and sending a map that you downloaded off the dynojet website. other than that, i wouldnt touch it
    Epsom NH
    well i can figure out how to make the old ass cable work through my usb adapter...so right now its tuned for a yosh full system i guess....i like pushing buttons.
  1. Need to borrow 9V Power Plug for Power Commander III
    By MikeyZ in forum General Bike Related
    Last Post: 07-17-14, 01:08 AM
  2. QUESTION ON POWER COMMANDER IGNITION MODULE ??????
    By playtwo in forum General Bike Related
    Last Post: 08-31-09, 02:55 PM
  3. power commander question..
    By Mystic in forum General Bike Related
    Last Post: 04-23-07, 07:52 AM
  4. Power commander question..
    By benVFR in forum Bike Maintenance
    Last Post: 10-28-04, 10:29 AM
  5. Power commander question...
    Last Post: 07-15-04, 09:26 PM
